Servo Torque for a fast .60 size
Reply
Old 03-27-2003, 04:08 AM
Michael_Flight
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Servo Torque for a fast .60 size
Hello Speed Demons,
I'm putting together a World Models Midget Mustang and am planning on powering it with an O.S. 91 FX 2-stroke. Since this will most likely be a very fast plane, does anyone have any recommendations on how strong the servos should be?
I'm asking this because I was planning on using Hitec 605's and a friend at the field (and postings on RCUniverse) have suggested that BB standard servos would be fine.
As a point of information, here are the stats on the plane ... http://www.theworldmodels.com/midget.htm
-Michael
Michael_Flight is offline
Old 04-02-2003, 07:39 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Midget Mustang....
I would prefer to use high torque, metal geared servos
for the ailerons, and elevator.
The Midget uses a torque rod set-up on the ailerons.
If all I had to use were Std. servos....I would modify
the wing and use two servos, and put a Std. servo on
each elevator (two).
Flyboy Dave is offline
Old 04-06-2003, 02:19 AM
pylon1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo torque
Ah Ha, the need for speed arises once again.
Try going to the www.multiplexrc.com web site. Under servos section (found off to the side) they have a formula that will allow you to determine the servo torque needed if you enter all the correct info. You'll find it surprising as we all usually tend to over compensate and over torque, but what the hey...peace of mind goes a long way.
pylon1 is offline
