engine porting
Reply
Old 11-17-2007, 10:46 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default engine porting
i am looking for info on porting; Schneurle, laminar flow (ST)
info & pics would be great
thanx
vasek is offline
Old 11-17-2007, 11:47 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: engine porting
http://www.google.com/search?hl=en&s...+flow+&spell=1
Flyboy Dave is offline
Old 11-17-2007, 01:27 PM
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Interesting, Duke Fox being the individual with this patent.
vertical grimmace is offline
Old 11-17-2007, 01:55 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....what patent ?
Old 11-19-2007, 04:23 PM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
gas or nitro?
revver bro ... i forgot my #
OLD_SLOW and in the WAY is offline
Old 11-19-2007, 04:55 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nitro
vasek is offline
Old 11-19-2007, 05:14 PM
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look here http://www.freepatentsonline.com/4638770.html
This is Duke Fox's application.
Old 11-19-2007, 10:33 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Liner and shaft timing are somewhat important, but look at what you can do at BDC to unshroud the boost ports. If you take notice, the piston skirt on most engines interferes with the easy transfer of gas at BDC. The trailing section of the cranks' counter weight can also be dished to assist flow into the forward boost port, this also helps smooth out the engine after you've notched the piston skirt and oval sectioned the rod. Another tip that has nothing to do with porting but will increase pumping action [volumetric efficiency] is to go with a Cyclon style backplate to decrease crankcase volume.
combatpigg is offline
Old 11-20-2007, 03:02 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Combat, OK, i found some info on "cleaning" the ports
-am still confused on the notches in the piston sleeve. I've seen it on the left side of the port & on the right hand side also. (?)
-if the counter weight is reduced, wouldn't it unbalance the engine?
-what is Cyclone backplate?
vasek is offline
Old 11-20-2007, 08:56 AM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not to worry about balance ... take an unbalanced prop put engine at TDC let heavy blade of prop fall to bottom and tighten
Old 11-20-2007, 10:57 AM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's something for ya:
http://www.rcuniverse.com/forum/m_5226191/tm.htm
There's some good/useful information...and a bunch of B.S. but if you're interested in doing some reading, it'll give ya something to do...
proptop is offline
Old 11-20-2007, 01:29 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a keeper! thanx top
vasek is offline
Old 11-20-2007, 09:56 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vasek, at either the Cyclon website or at the MACA [control line combat] website there is a photo essay about how the Cyclon .15 is built. These engines are amazing to see in action.
To visualize what I said about improving intake transfer into the boost ports, take off the back plate of your favorite engine and take notice of how the path for gas flow into the ports could be improved. I made a mistake earlier about which edge of the counterweight to dish out, it is the edge that immediately follows the crankpin after the piston goes past TDC on the down stroke, this is when you want the shape of the counterweight to help direct gas flow up into the boost port. If you have lightened the piston and rod, then removing material from the counterweight is a good thing. It isn't rocket science, just cut and try will do. The notches in the piston skirt will lighten the piston significantly. The piston will need to go into a holding fixture and vertically mill the excess skirt material away so you can keep the angle of the cut away from the exhaust port [instant ruined engine] and so the angle of the cut lines up with the direction of the boost ports.
Old 11-21-2007, 05:17 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah.Combat NICE little engine! i like the minipipe!!!
i would love to see the Jett inners to see the porting on it
any pics of that? (i've got 2 lx'ses but don't want to take'em appart)
vasek is offline
