Timing on a Jett or Nelson
Reply
Old 12-04-2007, 11:47 PM
5.0Rick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Timing on a Jett or Nelson
Hello,
Does anyone know what the timings and compression ratio are on a Jett or Nelson 40 to 50 size?
Rick
5.0Rick is offline
Old 12-05-2007, 02:52 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Timing on a Jett or Nelson
me too I would like to see the ports shape/size.
Anyone has pics of the insides of a Jett?
vasek is offline
Old 12-06-2007, 12:35 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which engine ?
bob27s is offline
Old 12-06-2007, 02:08 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob, 90LX would be nice!
vasek is offline
Old 12-06-2007, 05:40 PM
5.0Rick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bob,
Actually I am looking for specs on the SJ 46 or 50.
Regards,
Rick
5.0Rick is offline
Old 12-07-2007, 04:28 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Rick, i was talking about some pics inside of the engine. Didn't mean to high-jack the thread.
Peace-out,
Vasek
vasek is offline
Old 12-07-2007, 11:10 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok... here ya go...... no giant secrets
Note the radical port designs [&:]
Timing is pretty basic:
165 on the exhaust, and 130 on the transfers. Shown is a SJ-50 ABC on the right and a SJ-90LAAC on the left. Ports on the 60LX and 90LX are similar ... just timed a few degrees higher to trade the torque for more rpm.
The newer, (cheaper?), import engines have lower timing. The AX for instance. This gives them more torque to run the oversize props, but prevents them from unloading in the air. Trade there is slower, quieter and very user friendly - but at the sake of power. And the better engine designs include smaller carbs that draw fuel and throttle well with the larger props at lower rpms. That is where the standard consumer market is, so they are designing the right product for the market. And for most pilots, these are good engines to select from for many aircraft projects.
Nice thing with the sport jett engines --- you get power, the added rpm, and they are STILL user friendly. The performance comes from care in design, material selection, fab and fit and finish, crankshaft design, and the exhaust system.
bob27s is offline
Old 12-07-2007, 06:35 PM
5.0Rick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bob, that is exactly what I was looking for. Do you know what the compression ratios are?
Regards,
Rick
5.0Rick is offline
Old 12-07-2007, 07:34 PM
Ed Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Compression ratios are generally misunderstood by most people.
There are two types of compression ratio. There is geometric compression ratio and actual compression ratio. Geometric compression ratio is determined by the stroke of the engine, BDC to TDC. Actual compression ratio is determined by the distance the piston travels from the closing of the exhaust port (usually the highest port) to TDC. If there are any doubts ask this question. How can there be any compression if the exhaust port is still open. Which ratio do you want.
Ed S
Ed Smith is offline
Old 12-07-2007, 07:51 PM
5.0Rick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Ed Smith
Ed S
Thanks for the explanation Ed. I am looking for the actual compression ratio (from the time the piston moves above the exhaust port). I find it interesting that many folks mention compression ratio and shims and nitro % without really discussing the actual compresion ratio. I am also an automotive enthusiast and compression ratio and fuel selection go hand in hand in that space. Thing is, in that space most people measure their compression ratio and make decisions on fuel octane based on imperical data and not on inconclusive data. I guess I would like to take the same approach. I took all of the measurements from my Rossi 53 to calculate the compression ratio and plugged the numbers into a compression calculator and came up with 8.94:1 Here is the calc that I used http://www.rbracing-rsr.com/compstaticcalc.html
It would be nice to find some info on what the recommended fuel is (Nitro%) for a given compression ratio. Do you know of any such source of info?
Regards,
Rick
5.0Rick is offline
Old 12-08-2007, 05:18 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bob27s
Yeah Bob, i was hoping for something more spicy [>:]
at least is the piston rod a bit "profiled" ?
posting pics of what i was hoping for (in a less radical rendering of course)
Peace-out,
Vasek
ID:	820937   Click image for larger version
ID:	820938   Click image for larger version
ID:	820939   Click image for larger version
vasek is offline
Old 12-09-2007, 05:12 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nah... nothing that goofy looking inside....
Its just normal lookin parts.
Dub told me a store some time ago about his early speed engines.
He bought a Fox .29 .... went 130 mph
After a few weeks of porting and polishing and airfoiling... it went 129.
Just because it looks pretty doesnt mean it runs better
bob27s is offline
Old 12-09-2007, 06:11 PM
Lomcevak Duck
My Feedback: (14)
Lomcevak Duck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vasek- what's with the channel below the port in the first pic there?
Lomcevak Duck is offline
Old 12-10-2007, 03:57 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Duck- the channel allows for more mixture to make it's way to the chamber (keeps it away from the exhaust port where it just "exits" unexploded )see pic 1. More or less the tune pipe also "redirects" the exiting not yet exploded mixture back to the chamber. Thus the power surge.
ID:	822665   Click image for larger version
ID:	822666   Click image for larger version
ID:	822667   Click image for larger version
vasek is offline
Old 12-10-2007, 05:04 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bob27s
I know what you're saying Bob, but that's NOT how the West was won! If you get my drift
vasek is offline
