Estimate of Sig Kobra Speed
Reply
Old 12-26-2007, 04:28 PM
frenchie79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Estimate of Sig Kobra Speed
OK Speed boys, I have a Kobra with a os 46Ax and a 9x7.5 prop and turns it right at about 16K on the ground, the Plane weighs 3.5 lbs. We will never have a radar gun so can someone with knowledge of this plane tell me what the level speed could be-I know it is a guess or an calculated answer.
frenchie79 is offline
Old 12-26-2007, 05:33 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Estimate of Sig Kobra Speed
You may be on the high side of 100 mph. Why not get an audio of a high speed pass and we can check it using Doppler.
Mike Connor is offline
Old 12-26-2007, 05:40 PM
gsoav8r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My 2 cents even thou Ive never owned a Sig Kobra.
Just based on RPM vs. pitch the numbers say 113 mph.
Initial guess based on drag and having fixed gear one might say 105-ish.
However thou, the thrust numbers for your engine/prop combo suggest your making 5.5 - 6 lbs.
This makes me believe that your Kobra may see 115-ish on a good cool day.
Cheers.
(Ive got my fire extinguisher handy. lol)
gsoav8r is offline
Old 12-26-2007, 07:00 PM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Simply measure a distance at the field, 200 or 300 feet. Then put a stop watch on the time to travel the distance for three passes (need to average the timing error). Someone can then calculate the speed for you.
Bill
BillS is offline
Old 12-26-2007, 10:11 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It should go about 110, no problem.
FBD.
Flyboy Dave is offline
Old 12-26-2007, 11:11 PM
frenchie79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys-I will do both this spring. Audio? Use a video camera or just record sound? I don't understand the doppler-small club!
Old 12-26-2007, 11:26 PM
Mike Connor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: frenchie79
I usually extract a wav file from a video but all I need is the sound of a high speed pass as it it coming at you and going away form you. A program takes care of the rest.
Old 12-28-2007, 12:03 PM
johnfly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what program are you talking about mike ??????
johnfly is offline
Old 12-28-2007, 12:14 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you may want to try and find an APC 9 1/2" x 8 N prop, seems to work pretty well with that motor. I'm guessing your a little over a 100 mph, with potential closer to 120 mph with the right prop combo.
daven is offline
Old 12-28-2007, 12:57 PM
Mike Connor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: johnfly
http://www.sprut.de/electronic/soft/scope.htm
It is in German but I let Google tranlate the page.
Old 02-07-2008, 09:52 PM
toro_0397
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does the sig kobra requieres any mods?
toro_0397 is offline
Old 02-08-2008, 08:20 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet little project!
I leave the speed estimates to these guys, but no matter what the speed that is an awesome little ship!
I has that same airplane in the 1980's and used an OS-28F engine and it was fast then!
Cheers
Razor-RCU is offline
Old 11-02-2008, 08:15 PM
wpvrtis
wpvrtis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a Kobra with a K&B .48. I put my Garmin GPS in it and clocked it at 125 with a 10x8 prop. I had a 10x7 3-blade prop in it and clocked it at 121.
ID:	1064262   Click image for larger version
wpvrtis is offline
Old 11-02-2008, 09:31 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I look at your plane and 115 would be my guess. that MA prop is closer to a 5.5 pitch not 7.5 compare it to an apc and you will see.
a APC10x7 would be my choice or maybe a 10x8 trimmed down some. you have another 10-15 mph left in that plane though.
1. put the ant. in side the plane
2. try get you tail servos back inside the plane too.
3. get rid of the MA prop LOL not really speed props or not as good as the APC's
4. try some Jett race wheels
5. get rid of the tail wheel and use a wire skid back there if for all our speed for that airframe.
I do like the that plane and looking at yours will inspire me. I have a 60lx looking for a home.
airraptor is offline
Old 12-22-2008, 01:30 PM
cptcrusty1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built my Kobra Almost the same as wpvrtis' Kobra and used his Garmin GPS. I couldn't believe it when I got it on the ground, but I have witnesses. With a new, unbalanced MA 10x6, I got it up to 149mph!!!! Not bad for a little plane. I plan to use a better prop (APC 9x8 maybe) and see if that does me any better. Oh.. and I wasn't flying with the wind either.. I was flying cross wind, low altitude.
Mods? trike to taildragger. Moved LG blocks forward. Used hardwood where the LG blocks where and made it span the wing center (really strong). OS 46AX. twin wing servos HS 225 (stripped them with the standard plastic gears, bought metal, works great). HS 225 (with MG) for Elevator. F16 tail. Seperate servos for Rudder and tail wheel on y-harness. All servos except throttle in the tail. All internal.
I also didn't put the canopy or turtle deck on. Lastly, the landing gear wires in the pictures are different now. They were long to allow for a big prop to clear, but now I shortened them to the orginal size. Problem is I almost always smack the prop.... Gotta learn how to land this thing... its FAST!
ID:	1094482   Click image for larger version
ID:	1094483   Click image for larger version
cptcrusty1 is offline
Old 12-23-2008, 05:23 PM
frenchie79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could change the wheels to e-flight micro wheels in 2" size. They still have some foam and give a little prop clearance. The biggest prop i can use is a 9". The APC 9x7.5 or 9x8 work I think i even tryed a 9x8.5?. This plane is as fast as i can handle. Lands like a dream- not fast at all, just takes along time to bleed the speed.
Found the wheels-2.5" from Dubro
http://www3.towerhobbies.com/cgi-bin...6&I=LXTDS7&P=K
Old 12-24-2008, 08:01 AM
cptcrusty1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I noticed you also went with the f16 tail config. How did you do the tail wheel? Mine was a pain, but only because I tried a different setup that broke right after I boxed in the fuse...
Old 12-24-2008, 08:27 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Humm..................Not one of you guys are using .19 to .35 sized engines that’s recommended by SIG.
I must be in the right place.......
Merry Christmas Ya bunch of speed freaks !
freakingfast is offline
Old 12-24-2008, 08:36 AM
cptcrusty1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone use the recommended engine size?
Old 12-24-2008, 08:55 AM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cptcrusty1
Not since my trainer with a K&B .40
Crazy4Flight is offline
Old 12-24-2008, 09:00 AM
cptcrusty1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was a rhetorical statement.. .LOL
Old 12-24-2008, 09:01 AM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put a .15 on a SIG wonder.
Correction TWO .15 on a SIG Wonder
Old 12-26-2008, 10:14 AM
frenchie79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used a Pull/Pull set up for the tail wheel. If i did it again i would just use a skid and forget it. Takes off in 5 to 10 feet. Sorry so long on the reply.
Old 12-26-2008, 01:21 PM
cptcrusty1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hopefullly, WPVRTIS and i are going to race them today... should be sweeeeeeeet!
Old 12-26-2008, 05:25 PM
frenchie79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have got to MOVE-Wisconsin sucks 6 months out of a year. Screw Ice fishing. I wanna fly!
