OUTLAW from EXTREME FLIGHT
Reply
Old 03-09-2008, 07:31 PM
  #151
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OUTLAW from EXTREME FLIGHT
I put the tap on the header opposite the exhaust port or at the apex of the pipe. On the Outlaws I put it on the header, the aluminium is thicker there and it holds up longer. Use JB Weld around it.
Pile driver, point her straight down get some speed then chop throttle, full down, full right aileron, and full left rudder.... stops on a dime. Just as fun is a reverse pile driver fast fly in from the left or right, at center stage point it straight up, at the same time cut throttle, wait till she climbs about 50 feet and do the same thing. After she's done flipping nail the throttle and give it full up elevator and full left rudder and you exit into a flat spin.... Timeings everything...
evan-RCU is offline
Old 03-09-2008, 08:10 PM
  #152
griffin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys,
I think I'll go with freakin and use a 90 at the apex. I didn't read macs suggestions on there website about placement until just now when I went to look for the fitting. I still think they should include it with the header and pipe though.
Thanks for the tips Evan. This is just too much fun !!! LOL
griffin is offline
Old 03-10-2008, 12:48 AM
  #153
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sparky925
personally i like the regulator better...more stable at all RMP, all be it more costly...
could always use a regulated pump insteay..like perry ossilating pump.....
Cline and Irongate regulators(on demand types) are fantasic systems for stock carbs and have their place but I don't think this is one of them. Both end up costing about $ 70 with shipping and fittings. Time for a low cost China copy? Hint, Hint.
The fuel tank on the Outlaw is close, small and well centered with the carb and a pump isn't needed. It just adds weight. Same thing goes for both types of Perry pumps but if you did use one, you should use a carb thats designed for pump pressure, like a Perry "PUMP" carb or the mid range would be so fat the engine won't transition to high speed well or the engine would just choke and stop.
Do try to lightly stuff some strips of Dubro foam rubber around the tank, but there is only about an 1/8" on the top and botton of the tank in an Outlaw.[]
By the way, isn't that a crazy place they put the antenna tube? It could have came through the shear web just next to it.
freakingfast is offline
Old 03-10-2008, 01:39 PM
  #154
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: griffin
Thanks guys,
Yup, this spells it out. Humm, see the note in red.
http://www.macspro.com/pressure.asp
Old 03-14-2008, 09:31 PM
  #155
c/f
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The problem with fuel fed motors in this plane is it does'nt matter, even with a pump, that you cannot overcome the high G manuevers and its effect on atmospheric pressure to push your fuel to the carb. Bladders will soon be in your vocabulary,,,, or perhaps as I did, AMPS, OH YEA........100oz of thrust and 54oz ready to fly weight.
c/f is offline
Old 03-24-2008, 12:28 PM
  #156
Mike Parsons
Mike Parsons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thought I'd share a bit of Video from my Outlaw flight on Saturday. Not tricks as we were testing batteries and props. Still pretty fast, but shooting for faster
Outlaw
Torque 8T outrunner
Airboss 80a ESC
9X8 APC prop
5S 4000 Lithium
http://www.youtube.com/v/Dq3qsjfH3cM
ID:	912258   Click image for larger version
ID:	912259   Click image for larger version
Mike Parsons is offline
Old 03-24-2008, 04:02 PM
  #157
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice ! That flat firewall is costing you just a few ooomph !! [:-]
Strykaas is offline
Old 03-26-2008, 11:50 AM
  #158
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice new video on http://www.extremeflightrc.com/video...264_960_3k.mov !! Featuring two crashes [&:]
All three Outlaws seem to use Webras... [:-]. And the 'servo arm through ventral fin' mod has been adopted by all of them. Come on, get that manual up to date !!!
Strykaas is offline
Old 03-28-2008, 12:14 PM
  #159
iflyg450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What kind of speed will the outlaw arf do with a OS .25FX+jett tuned muffler?
iflyg450 is offline
Old 03-28-2008, 12:42 PM
  #160
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
115-120 level on a 8X7 APC.
evan-RCU is offline
Old 03-29-2008, 06:42 PM
  #161
iflyg450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What would be the better engine a OS .25FX or a Tunder Tiger .36PRO? I have has great results with the TT .46 on my laser arrow, never messed with the .36. Yes I know the .36 is is bigger than the .25, but the .25FX is pretty powerfull for its size.
iflyg450 is offline
Old 03-29-2008, 06:51 PM
  #162
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Without a shadow of a doubt, the TT .36 Pro is a better engine. Install a mousse can pipe or better a tuned pipe and you're not far from the optimum setup.
Strykaas is offline
Old 03-30-2008, 08:35 AM
  #163
iflyg450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have had great results using the jett tuned muffler. with the engine mounted on the side on the outlaw will the jett muffler clear the top of the plane. I have never made a mouse can. what would be the right stuff to use for the tt 36 such as can size header length and prop?
iflyg450 is offline
Old 03-30-2008, 08:57 AM
  #164
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the information that I have at hand :
[link]http://webpages.charter.net/rcfu/ConstGuide/MCM.html[/link]
[link]http://www.personal.psu.edu/faculty/d/m/dmd7/RC%20Modeling/Mousse%20Can%20Mods/mousse%20can%20mods.htm[/link]
Strykaas is offline
Old 03-31-2008, 07:49 AM
  #165
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Something caught my eye on the latest Outlaw vid (with Rob Vess). It seems as if Robert Vess uses a Vess prop on his ... I've checked the Vess props web site, and no such tiny prop is listed. Are they currently experimenting small props ? How do they perform versus apc ??
Killer vid, I've watched it again, very cool editing / music sync. [sm=thumbup.gif]
Strykaas is offline
Old 03-31-2008, 07:56 AM
  #166
wttiger42
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
East RC for vess props
[link=http://www.eastrc.org/shop.cgi/page=estoreprops.htm/SID=1206968106.9853]www.eastrc.org[/link]
wttiger42 is offline
Old 03-31-2008, 08:12 AM
  #167
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks indeed, that's new [8D]
Strykaas is offline
Old 03-31-2008, 09:31 AM
  #168
rich3d
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a great video of Team Outlaw and their set of three Outlaws.
The link is at the home page at www.ExtremeFlightRc.com
[link=http://www.ExtremeFlightRc.com]Extreme Flight RC and the new Outlaw[/link]
rich3d is offline
Old 03-31-2008, 12:18 PM
  #169
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rich3d
This is a repost, see post#158.
Strykaas is offline
Old 04-19-2008, 03:58 PM
  #170
ArthurD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The .36 Webra is ideal for the Outlaw and it can be found at cswartz@mts.net. That's Cliff Swartz, a Webra dealer in Canada, and can sell you all the Webra's you want. The .36 Webra, a 9X7 APC and a tuned pipe are a perfect combination. Ask the guys at Extream Flight.
ArthurD is offline
Old 04-24-2008, 04:41 AM
  #171
gofastz
gofastz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have owned 2 of the outlaws and can tell you that you have to think way ahead in what you want to do with it as it will cover alot of ground in a hurry...Speeds of 150 to 160 mph is the norm with the engine pipe combo ArthurD is using...However, I had Dave at ultrathrust make me one of the mufflers that was designed for the webra 32 racing....Bolted it to my 36 webra and it was like a turbo charger.....9x7 acp and a screaming 36 webra will set you free.....gofastz
ID:	935847   Click image for larger version
ID:	935848   Click image for larger version
gofastz is offline
Old 04-24-2008, 06:20 PM
  #172
ArthurD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Evan,
Looking at the picture of your Outlaw it seems your header is much longer than mine after tuning. Maybe by two inches. Did you tune yours later and this is just a picture before you did it?
ArthurD is offline
Old 04-25-2008, 11:37 AM
  #173
ecoliburger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do these things land really slow? Got mine build and the rud servo looks like it will be the landing skid, sticks out. The pictures I have seen looks like this is how they are just seem like the servo would be easy to damage on landing.
ecoliburger is offline
Old 04-25-2008, 07:02 PM
  #174
ArthurD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can put the rudder servo inside the fuse on the right side in the compartment under the removable fin with the servo arm straight up through a cut-out you make in the cover. The push-pull rod will lie flat almost touching the top of the wing on it's way back to the rudder. Place the control arm on the rudder at a height to allow this clearence. It might also go on the left side in the compartment. Didn't try that.
ArthurD is offline
Old 04-26-2008, 06:39 AM
  #175
gofastz
gofastz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ArthurD has got it right !!!!! Cliff Swartz at SWIFT ELECTRONICS has been invaluable with his knowledge of WEBRA engines....Not only can he get you one at a great price but he can help you get every ounce of power out of the engine you get...It is obvious he has the experience from many years in this hobby... I highly recommend him for you WEBRA needs.... Believe me it's a refreshing change to contact a supplier and have him take a genuine interest in what you what to achieve.....His wife Fay can also be very helpful....Now I know I sound like a commercial for these guy's....But, I am telling it like it is.....These forums are for exchanging ideas and finding help with issues that always crop up in this hobby...It always feels good to be able to pass along a treasure that we all can share......Gofastz
gofastz is offline
Reply
Display Modes
