My new speed plane...advise needed
#51
FL
RE: My new speed plane...advise needed
ORIGINAL: Mike Connor
You are right about Highplains refering to Rudeboy's post but after reading Rudeboy's post for years his knowledge is usually beyond most.
ORIGINAL: remcl1
I think Highplains was refering to Rudeboy's post was bull. All except what Highplaines quoted. At lest that was the way I read it.
Now when someone names them self rudeboy, how do you expect them to act. Yes I do think it was rude to basically say junk everything you have and start over, when the question was how can I squeeze a few more MPH out of this plane.
That may be true. I did not say he lacked knowledge. I said he was Rude. In fact I am sure he has a considerable amount of knowledge and that is why he has a hard time in just answering a simple question. I am sure to him there are no simple questions. He has to look at it from several angles and when everything does not fit just right you clear the slate and start over. Anyway, I am sure he means well.
#52
lol!! yea why not have some fun with it. would it be posible for a video of the plane flying after you put in the bigger tank if not no probs
thanks anyway
thanks anyway
#54
FL
ORIGINAL: simmo8
thanks anyway
thanks anyway
I volunteer to take video. If I can keep up with it.
#56
FL
ORIGINAL: Scorpion Racing
Great job Mike, I knew you could do it!! I guess this means the race for a speed king is back on? I will leave you alone till after the race in March, then you better look out buddy!
I am sure you know the MEERKAT - scorpion eater decals now make it personal!!!!
Great job again...
Great job again...
Your the true plane designer and the scorpian is impressive. But yes, I had to have fun with naming it with you in mind
#57
ORIGINAL: remcl1
#59
FL
Easier to link than to tell . Here is a link to it on Garmin's site. Nice thing about it is its size and weight.
https://buy.garmin.com/shop/shop.do?cID=144&pID=220
#60
FL
All I need is the sound to do a Doppler. I hope I will prove the gps right, not wrong.
ORIGINAL: remcl1
#61
ORIGINAL: Zman39
You know rudeboy..........ah nevermind.
Anyway, my goal was to never set a world record speed, just a bit more then what I have achieved so far.. I had a Jett laying around and slapped together a fuse much like quickie planes and then had my "laminar" wing cut from a foam cutter. I then sheeted it, etc etc. So far the guys here have had some good ideas. If I dont get there, so be it, it is still a fun plane to fly around with and I had fun with the project.
Z
Z
ORIGINAL: Rudeboy
You cant' build a laminar flow wing by hand... You just can't achieve the accuracy that is needed, unless perhaps you spend 2 years shaping it to perfection with laser cut gauges.
Forget laminar flow.
If you are looking for straight line speed, start by making your wing only half as thick. 1" is way too fat.
Build a decent fuse, instead of a square box.
Use a rear exhaust racing engine, and cowl everything. If you insist on side exhaust, at least cowl the engine as good as you can.
Airfoil your tail.
All internal linkages.
Loose the landing gear.
If you use a Q500 muffler, you must prop the engine to run at Q500 rpm: at least 19000 rich on the ground, preferably a bit more and unloading in the air. I don't know if the SJ50 will support that though...
Airfoil your tail.
Airfoils - what he says is quite true, an accurate job of reproducing a low drag laminar flow airfoil really cannot be done by hand, but one can certainly do one's best to get close with whatever techniques you have at hand. To take real advantage of low Reynold's number low drag airfoils, you need very accurate reproductions, generally involving CNC cut female molds and good composite construction techniques - not everyone's idea of a quick home workshop project. But you originally said you had a laminar flow airfoil, and he simply resopnded by saying you can't build one by hand. You were mistaken in your terminology, he responded correctly based on your terminology - relax. Highplains pointed out that by avoiding valley, flats, edges etc. you can improve the tendency to keep flow attached - also quite true, but I have my doubts that one can achieve full laminar flow. IMHO the jury's out on that one.
Wing - thinner airfoils favor high straightline speeds. Heck, you could build a second wing and shim the wing saddles to fit without rebuilding the entire airplane, if you chose to do so. It could even have internal aileron linkages. You could compare the benefits.
Rounded fuselages - yes they reduce drag. A slap-together fuselage could incorporate more rounding with fairly simple construction techniques.
You can indeed reduce engine drag by cowling or rear exhaust with or without cowling to reduce frontal area. It is feasible you could fit a rear exhaust engine to an existing design, with or without cowl. Maybe you have one, maybe you don't.
Airfoil the tail. True - many people neglect decent attempts at tail surface streamlining. Not all, but many.
Internal linkages. Not hard to do, good idea. Hard to do on an existing model, yes. But not hard when starting from scratch.
Landing gear - yup, simple and practical. Remove landing gear and hand launch. This is something you could do with your existing aircraft and as you were looking for in the first place, you would indeed squeeze a few more mph from it.
Using a Q500 muffler - correct advice there, and something you could do with no structural changes. And yes clipped pylon props often work out well if you have sufficiently small frontal area to take advantage of them. This too, is practical advice you could try out.
Part of the European style of response on this forum, if I can grossly generalize based on observations, is that there appears to be a lot more effort by modellers over there to build dedicated speed models - true "extreme speed" models - using many of these known techniques for drag reduction. And again to generalize, many of the European crowd seem to be puzzled at the term "extreme speed" used freely on this side of the pond when referring to either prop jet ARF's, or quickies with .50's, or sport models with monster engines, or whatever. It all depends how fanatical you want to be. I guess they don't view "sport speed" as "extreme speed".
So.. you have a choice of taking or leaving his comments. You could look at them and decide to yourself that you may make another one down the road, and see how many of those ideas could be incorporated in whole or part in a simple sheet balsa/foam sport speed aircraft. Might be an interesting and rewarding project. Or you could simply choose to respond with "thanks, but I don't plan on making all those changes, but might see what I can do with some of the ideas".
My point is, instead of people pissing on RB because he posted a list of known drag reduction techniques some of which would require redesign/reconstruction of the current design, but many of which could easily be incorporated into even a simple model from the outset, maybe just read it and take the positives from it and say thanks. I don't see how he had the intention of insulting anyone. It may be that he stated some obvious design issues, but so what? It's your choice whether you take insult at that or not. The point of forums is to learn and share, and he has all the right in the world to offer his ideas on the subject.
That's my $0.02.
MJD
#62
FL
Original first post by me was asking; here is what I made, anyone got any ideas on how to get a few more mph's out of it. RB's response was to "summarize" change the wing and change the fuse. That would have been a good response if my question was "here is what I made, didnt work, need to start over, any ideas? Insulted? no way, just a post that didnt address my question at hand.
But, at this point, none of it matters, I achieved my goal and am satisfied.
Z
Oh and I agreed about 15 post or so ago to not call it a laminar airfoil anymore. It's official name is BS airfoil which means don't have a clue what the airfoil is but worked fairly well.
Z
#63
ORIGINAL: remcl1
Tell me about how this dopppler works and why is it more accurate getting its data from a video than an on board GPS?
It is a program that measures Doppler effect from a sound file to determine speed. Here is a link to the program if you care to read (translate from German) or download and play with it.
http://www.sprut.de/electronic/soft/scope.htm
#64
ORIGINAL: Zman39
Anyhow, that makes it either a Staedlter-Mars or a Bata airfoil, depending on whether you used a french curve or a shoe for the profile.
One day I'll get around to finishing up rev. 1 of a sport speed design using normal/fast/simple construction. Me and a few others I reckon. It's "on the list"..
MJD
#66
My Feedback: (98)
Thanks, I just bought one for $30.27 off pricegrabber.com
I have a few planes I'd like to try it in for speed, but I fly in a park with boundries and I'd like to see if I am staying within bounds.
#67
FL
ORIGINAL: soarrich
That is a great deal! You will like it Rich, nice little unit.
Z
#69
My Feedback: (13)
CA
Zman 39:
Love the way your mind works, keep it up. Also learn to listen to CP, a great source of good information among many. Based on 6 years experience racing a 40" Q-500 wing, thats all it takes to turn and land well. Also did a 40" wing with Jett 60LX, darned fast, flew well, and landed just fine thank you. If your jett 50 is not the LX model, your not going to get much more out of her. The Jett Q-500 black pipe will give you a few more rpm's but not a bunch. Your general design basically follows my time proven "Yellow Jacket" design, which is basically what you have except the nose extended and widened for a 10oz tank and the rerar end extended to offset the nose weight. If you gotta add weight to CG, your just to lazy. Right now, you are into a speed zone where streemlinning is required within reason. What you have is fine except for the nose. You can add some balsa up front or use other cowel approach and find around 8-10 MPH IMHO. A bad switch killed my first YJ design with a 40" wing. Had enough flight time to find that that is enough wing, period, and no did not skid in the turns. When building new #2, had a composit 52" wing laying around that I ended up using. With the Jett 60 LX power, you can start her, needle, set it down and taxi out and take off like any other sport airframe. You can keep the speed down to get used to the thing. So far, none of the local all out Q-500's or formulas have outrun her WFO. It will happen eventually I am sure, cause there is alwlays someone bigger, stronger, faster, in the intrum I fly around with a big grin on my face at less than 1/2 throttle. Unfortunately, there is seldom a challanger. Oh yea, it will hover, try that with your Quickees guys. Will try to attach a couple of picks, ENJOY
