Question for Bob
Reply
Old 01-25-2008, 06:51 PM
Erik R
My Feedback: (32)
Erik R's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Question for Bob
Hi Bob,
I'm going to run an OS 91FX with a Mac's 15cc nitro pipe in a tiporare.Planning on using an apc 11x8.Figure 14-15k.I'm looking for a starting length for the pipe(measured from the glow plug to the widest part of the pipe).I've been thinking about putting a Jett 90lx in there,but I have this OS sitting around.Thanks in advance for your help.I will be out of the country,and computerless for the next week,so if I don't respond right away,it's not because I'm unappreciative of your help.Thank you,and stay well,
Erik
Erik R is offline
Old 01-28-2008, 12:06 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Question for Bob
ORIGINAL: Erik R
Hi Bob,
Erik
Nothing at all wrong with the OS91 engine.... its runs great. Really likes the tuned exhaust
But its timing is a bit mellow - it has good torque .... try targeting the low end of your range, closer to 13-14K --- maybe a bit more prop like 11x9 or 11x10.
Going by how I set up the .61 engines years ago....
Start with the pipe set at 13.25" This will likely be a little bit long, but its easier to keep cutting than swear at a short header.
Measure from the glow plug, along the CL of the header - up to the weld in the pipe (end of divergent section - max diameter).
That will be a good starting point. You will probably end up around 12.75 when done, so plan mounting accordingly. And of course, do the tuning on a test bench first.
Id suggest running it at that initial pipe length, then going up and down in prop size - its easier than cutting the pipe initially - just to give you an idea of how much too long the pipe is. When you get to a big prop where the engine does not run right, or rpm starts falling rapidly, that is the tuning length rpm. Who knows, you might find a prop/pipe set up that surprises you
Enjoy the trip!
Bob
bob27s is offline
Old 02-03-2008, 08:11 AM
Erik R
My Feedback: (32)
Erik R's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Thank you very much.
Erik
Erik R is offline
