H9 F22 raptor propjet
it doesn't look half bad to me
http://www.hangar-9.com/Products/Def...22raptorptsarf
has this been posted b4?..if it has ..sorry
RE: H9 F22 raptor propjet
I'm not sure if it's been posted before but it's by no means a speed plane and most people with even minimal experience in sport flying will be very disappointed with it.
My Feedback: (13)
CA
Blue buddy!!
Club member has one, very expensive but well done. Flys ok in a streight line only, will snap if you try to turn anywhere near tight. For a frew dollars more, you could have my Miss Ashley, one of those good flying Formulas that scoot around the 200 mark with a good engine. he he he. After all, its a scale airframe guys, sort of, just a little on the quick side. (For the benefit of my club guys) EnJOY
TX
You guys have this little plane all wrong.
I have mine powered with a 55ax turning a 10x8 w/ stock muffler turning 13.5k rpm's. This plane flies great!!! I can slam this plane from level flight into some very tight corners. Your are correct on 1 thing tho, its not speed demon it only runs around 60mph.
I have one its ok evo 52 on 10x6 prop over rev's the motor a little speed is over 60 mph around 80+ or more in a dive
may want a shrike or quicke 500 instead if you wan't to go faster
it is a nice plane depends on what you like
