Building RCM F-18 Pusher Prop Recommendations
Reply
Old 02-10-2008, 12:43 AM
Jim_Purcha
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Building RCM F-18 Pusher Prop Recommendations
What size and pitch of pusher propeller do you fellows recommend for a RCM F-18 0.40 Pusher model? Planning on using a supertigre GS-40 or GS-51?
Jim
Jim_Purcha is offline
Old 02-10-2008, 03:32 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Building RCM F-18 Pusher Prop Recommendations
Most folks would probably say start with an APC 10x6 if you have enough ground clearance then go from there. The 10x6 is not going to make it very quick but should give you a good combination of take-off power and a bit of speed. Really depends on the size and weight of the aircraft- Keep us posted!
Razor-RCU is offline
