Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
Magnum engine issues, please tell me they are better than this!
Reply
Old 04-22-2003, 12:33 AM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Magnum engine issues, please tell me they are better than this!
Ok, first question, who services the west eurotech 50 engine in north america?
Secondly, please tell me these engines are better than this experience.
here is what happened, now, before you think I fudged something up, here is my background experience.
I've flown high performance engines alot, Nelson, YS, Ducted Fan, and turbines. I don't run them lean, I don't NOT follow instructions.
So what happened, that's what I want to know.
Situation:
Airplane: Magnum
Engine: West Eurotech 50 with supplied header and pipe.
Prop: APC 9x7
Fuel: Power Master 10%
Plug: K&B
Temp: 18C (about 66F)
So, I do EXACTLY as the instructions state. Needle open 1.5 turns from closed, Prime engine, connect ni-starter, and the engine starts instantly. Let it run about 40 seconds at that setting and throttle up. At about half throttle, I hear POOF and a puff of smoke comes out the pipe (and it's still rich, the fuel and mess on the back show that)
So, the engine quits right after that. I pull the plug, the coil is smashed up inside the plug and little bits of metal are all inside it.
Very pissed off, I pull the engine, pull the head, uh oh, metal everywhere. Mark and pull the liner, hmmm, no scores, pull the piston, hmmm, conrod bushing doesn't fit the crank pin at all, it's very loose, pull the piston, the bottom of the piston skirt is broken. I mean a BIG piece of the skirt is missing!!! Well, I know where it all is, it's not really missing, just mostly through the engine and pipe. Ironically, no scores on the piston either. Just broken, clean away.
So, what gives? the engine wasn't hot when it quit, there was lots of fuel residue, and I have run engines of this type before.
So, I guess my main question is, who services these engines in North America, and how long am I going to be without an engine?
Jeremy
LGM Graphix is online now
Old 04-22-2003, 02:35 AM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, the host my pictures were on is screwed up, so no point in having them there :S
Old 04-22-2003, 08:42 AM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks like you did nothing wrong, just a $h*t happens got a bad one. micro fractured piston caused the crank to go which caused the skirt to go more which caused the crank to go more, you know the story then pop.
if you were in the UK you'd get a three day turn around, no idea over the pond.
We've had nothing like this here, nothing even aproaching a problem and its fair to say our club has some of the very first V1's and probably get more running than most. Other than the tunned MVVS 40's nothing we've seen here lasts better, tho we did kill a few 40's from over use, like i said, the 50's are still strong.
Cactus. is offline
Old 04-22-2003, 07:55 PM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a phone call from Alan at Weston UK today, they have wonderful customer service. He informed me that my engine makes #6 out of over 2000 sold that have had this problem and that they will ship me a new engine ASAP.
Despite the engine problem I had, due to the customer service provided by Weston UK, and Modelbau USA, I am still satisfied, I will post a follow up once I have the new engine.
Jeremy
Old 04-28-2003, 12:20 AM
klave
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the same problem, connecting rod failure. modelbau sent me a new engine right away, and I have had 12 flights on engine
with no problems. the magnum is rocket, flyes great.
klave is offline
Old 05-07-2003, 05:50 AM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My new engine arrived today, with the exception of UPS still being a totally worthless company that raped me with a broker fee, I will be putting the new engine in very soon.
Can't wait to run it!!!!!
A super big thank you goes out to Alan at Weston UK and Camilo at Modellbau USA, they have both shown outstanding customer service, and given me great confidence in their product!
Old 05-07-2003, 09:51 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it is truly the 6th engine out of 2000 that failed, that isn't too bad... I would consider a 0.3% failure rate on high performance engines like the West are normal (that's very good actually)... And thumbs up for them if they have the guts to admit that, and replace the broke engine without problems...
Rudeboy is offline
Old 05-07-2003, 11:25 AM
simonbsimonb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default west engine
looks like your screwed if you didnt use prosynth fuel then no warrenty is available
from weston uk
cant understand what happend though bad luck
iive two of these motors and both were hand started when running in with a rich needle setting on a 9x6 prop using prosynth 5 % ( difficult to start because piston ws very tight ABC typical ,but after two or three tanks engines run really sweet
now achiveing 22,000 plus on 10% nitro using 8x9 apc
simonbsimonb is offline
Old 05-10-2003, 12:55 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
6 out of 2000 is not bad, unless your one of the 6 :-)
Klave had one of the 6 and Modelbeau made good on it promptly.
Magnum flys great, fast, just needed a little tail weight
Crazy4Flight is offline
Old 05-10-2003, 04:24 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take a look at my post (#46) in this thread....
Did any of you guys meet any of the problems I met with the WEST engine?
This thread]
Rudeboy is offline
