new YS 45 with tuned pipe
Reply
Old 03-18-2008, 12:41 PM
JS615
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default new YS 45 with tuned pipe
Whats the best setup here,,, F20 tiger shark, ys 45 with tuned pipe,,, what would be the best overall prop, and where should i start as far as the header length??????? What should i expect for rpm, best! without destroy the engine to quick!
JS615 is offline
Old 03-18-2008, 06:18 PM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: new YS 45 with tuned pipe
I've got one of the RE 45 engines NIB. I've seen one in a Prather Toni running pylon quickie props, and I think the RPM was in the 16K+ range. The note that I threw into the box with the engine was a header length of 5 1/2" measured from the plug with a Mac's pipe.
HighPlains is offline
Old 03-18-2008, 09:05 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YS 45 FR, FS tune length with a Macs MARINE muffled pipe (#1349) tuned length 11 5/8" measured from glow plug to large diameter apex on pipe. Note, start about ½” longer than this and tune your own system, engine port timing and pipes are not all the same.
This measurement is the "stretched/strait" length or true distance from glow plug to apex (the high point on the pipe). It will appear shorter if you have a riser, doglegged header or side exhaust. I use a mini tubing cutter and debur the I.D., make sure the chips don't get in the engine. A good engine, broken-in & good bearings should see a minimum of 16,300 on 15% nitro with an APC 9X9 and a good tuned pipe, this is my benchmark. On 30% expect about 800 more. With a Marine (nitro) pipe I have seen 17400+. These are peaked numbers back off a bit rich for flight. If it lugs/sags in the air and there’s no smoke land and richen. In all cases it should unload a bunch in the air. This engine is finicky about glow plugs and realy likes OS #8s. If you use the full length header it will pull a good size prop at lower RPM's but it will be sad for speed.
a 9X9 prop is for a very clean plane like a Diamond Dust, Demon, Whiplash or a Quckie. A 10X6 has the same engine load and gives about 1 pound more thrust at the expence of a lot of speed. Try them both on the F-20.
http://www.macspro.com/tuning.asp
http://www.macspro.com/pressure.asp
freakingfast is offline
Old 03-18-2008, 09:33 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dont forget to run-in the engine with a 9X8 APC at a rich two stroke sound, wide open throttle. 15%nitro 18%syn&caster or more oil for run-in. It's best done on an engine stand.
Tune the pipe further AFTER run-in, three or four tanks.
Old 03-19-2008, 03:31 AM
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been running YS 45 for 5 years , on airplanes like ultra sport and patriot , my better results with this kind of airplane have been with 10x7 and 10x8 APC ( 10x8 strictly shaved and 20% nitro ) with tuned pipe 7.5 c.c. , I can't remember if the length of the header is 5" or 5 1/2 " , RPM around 15,500 and plug O.S. R5 . But this is just my case .
SpeedBoy is offline
Old 03-19-2008, 09:20 AM
JS615
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info guys, this will really help.. I got this engine from a friend, and its new in the box,, i know it has not been made in a while, but i was told that parts are still avalible... thanks again.
JS615 is offline
Old 03-19-2008, 09:26 AM
Grodus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a YS 45 RE with a Mac header and a Prather marine pipe turning a 9x9 APC. From the plug to the apex of the pipe is 12 3/4". Sorry I dont remember the rpm's and my tach is not working now but it is scary sounding. My is currently yanking around a Direct connection Dodger. I had the motor on a DC F-20 years ago. Experiment with a 9x9, 10x8. I think I liked the 10x8 better on that airframe.
Cody
Grodus is online now
Old 03-19-2008, 12:07 PM
still4given
still4given's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm running one on a BH Spitfire 40 with an Ultrathrust muffler. So far I like the APC 10x7. Turning about 16,400 on the ground. Great little engine.
Blessings
still4given is offline
Old 03-19-2008, 08:29 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There you have it, 9X9, 10X6, 10X7 and 10X8 (shaved?). Start plenty long on the header with the 10X7 & 10X8 and work down. Fuel, plug, prop, pipe & plane all work best if the header is tuned for each package.
still4given, 10X7 @ 16,400 W/Ultrathust, that's pushing 2 hp....as good as any pipe will do, Im impressed!
Old 03-19-2008, 09:24 PM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm running a 9/7apc on my F-20 with a Jett 50. IMHO the YS 45 with a tuned muffler or pipe is equal.
Cyclic Hardover is offline
