View Poll Results: A poll
Voters: 17. You may not vote on this poll
What would be a fast kit for a summer project?
MI
Hello,
Lately I have been intrigued by fast, agile planes and would like to know what would be a fast stable platform that I could use in a .40 size plane.
If you have built a stable fast plane I would really like to hear your suggestions.
Even if you haven’t built it but you know someone who has please tell me what your thoughts on it are.
I am wiling to take any suggestions out there and sort through them to find a fun plane that will blow my doors off.
Thank You, Flyer 202
If you select Other please state what it was and possibly a link
My Feedback: (50)
RE: What would be a fast kit for a summer project?
Well the Diamond Dust is great and so is the design by Mike Connors, can't recall the name at this moment. These are hand launched deltas is that okay with you?
ORIGINAL: Flyer 202
Hello,
Hello,
MI
I have never heard of the quickie 500 or the outlaw if you could supply me with a link that would be great.
I have looked at the viper and forgot to add it to the pools i will do that after this post.
ORIGINAL: Razor-RCU
...the design by Mike Connors, can't recall the name at this moment.
Screamin Demon and the Lickety Split
www.mikesrc.us
ORIGINAL: Flyer 202
Of course, deltas are cool too.
MJD
CA
Look at the matney model zoomer with a thin race airfoil option. Probably gonna be your best bet for a cheap go fast summer project.
Dust, Shrike, and Viper from your list are all OK. Outlaw is not a true speed plane though it is quick. The fat wing and rudder make it more of an acrobat, 125 tops. Also it's a .30 size working well with the lighter .32 to .36. A .40 size motor is too heavy.
I'd recommend a Magnum though, great speed flyer, great handling. After that a Viper or other Quickie 500 airframe.
ORIGINAL: evan-RCU
MJD
MI
Now that I have seen some of these choices I now prefer the full fuselage thin wing core so I can have stability and speed while having a speed demon.
My Feedback: (10)
I second the Magnum.
I fly Q500 all the time, if you have them set up with race throws they are fairly boring to fly around with. The Magnum with a speedy .46 will curl your toes. If you want to build, snag a Patriot, they are great speed ships if you build them light and right.
MI
I have made the decision on what plane I want to build here is the rundown.
Dominator 500 http://www.lanierrc.com/airplanes/lana3000.html
O.S. .46 AX http://www3.towerhobbies.com/cgi-bin...?&I=LXFMD5&P=0
Macs O.S. .46AX Muffler http://www.macspro.com/onepiece.asp
Hitec HS-55 (Throttle) http://www3.towerhobbies.com/cgi-bin...?&I=TC4043&P=7
Hitec HS-225MG BB (Ailerons, Elevator, and Rudder) http://www3.towerhobbies.com/cgi-bin...?&I=TC4051&P=7
Hitec Supreme IIS 8Ch FM http://www3.towerhobbies.com/cgi-bin...?&I=LXKYK3&P=7
Please Tell Me what you think of this any changes that you have in mind I will take in to consideration
Thank You,
Flyer 202
Thank You,
Flyer 202
My Feedback: (50)
Howdy Flyer- The black Macs muffler is a waste of money. get a Tower muffler or a Ultrathrust/ Jett muffler if you want to improve over stock performance. Also, I would not run the HS-55 in anything other than my little foamie's. Not sure if other folks use them for THR. though-
Keep us posted!
Keep us posted!
ORIGINAL: Razor-RCU
Keep us posted!
Keep us posted!
CA
If you want a small servo with plenty of durabilty HS-56HB is the way to go. I've used them to run the Vtail on a plane that went over 210mph.
MN
225 is fine on the elevators and ailerons, we've used them for years.
The Hitec 55 for throttle would be suspect. Look into the Hitec 85, they work well for throttle.
With the stock muffler (baffle removed) and that plane, we have seen speeds in the 120-125 range on a straight and level pylon course. I'd start with that, and then upgrade to the ultrathrust or jett if you need more speed.
The dominator is a pretty easy to build kit, but it does not come with hardware or landing gear, so you'll have to pick that up seperately.
MN
Also,
Lanier was sold to Tower, that link of yours works, but I don't think they have any stock to sell you. Tower had some blowout sales on Lanier stuff a few weeks back, not sure you can even get a dominator anymore...
MN
Just saw this in the swap shop. Nice stable sport speed quickie.
http://www.rcuniverse.com/market/item.cfm?itemId=379487
Not the $29.99 they were back then, but about the same as what the dominators were going for.
