West 50 V1, Questions
Reply
Old 03-25-2008, 01:26 PM
YUKONFLYR
YUKONFLYR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default West 50 V1, Questions
Did a search, anyone know if its ABC, is it a modded Webra or just the crankcase with West parts inside.
Any known problems.
Richard
YUKONFLYR is offline
Old 03-25-2008, 02:14 PM
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: West 50 V1, Questions
They used a Webra carb, case, head and crank and put in their own cylinder and piston. It's a great motor!
evan-RCU is offline
Old 03-25-2008, 05:28 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AWESOME engine-
Razor-RCU is offline
Old 03-25-2008, 08:41 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: YUKONFLYR
Any known problems.
Richard
Runs like an absolute bear and is not at all fiddly to setup, start, or run. The odd example seems to have had early running rod problems, mine included, but the repair and return service was top notch. Most have no issues whatsoever and I would not worry about it.
One negative with the motor is that it is side exhaust. With all that well-mannered power, it is a shame about the plumbing in the breeze. But somehow it seems to move along just fine anyway. I used 9-6, 8-8, 8-9 APC sport props at first [in a Magnum R] then moved to clipped 8.8" APC pylon props - I am currently messing with 8.8-8.5, 8.8-8.75, and 8.8-9 trimmed to 8.1 - 8.2", and hand launches are still fine (nothing like outrageous excess power) and top speed is smokin'.
If you're not running a Jett you'd be doing alright with one of these.
MJD
MJD is offline
Old 03-25-2008, 10:28 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran some numbers comparing the Jett-50 with the West-50 (just on a 9x8 apc) and the West had a 200rpm advantage. I admit though that depending on which prop. you use they can go back and forth but I was surprised that the West was up to the 9x8 job. 17.5K as I recall.
Old 03-26-2008, 12:48 AM
YUKONFLYR
YUKONFLYR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, sounds like a real runner......
I guess I will have to try out this engine with a side order of a Magnum to go with.....
Old 03-26-2008, 07:03 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: YUKONFLYR
Or a decent Q500 - I think you could mount it with the cylinder at 7:30 and the pipe underslung, I mean to try that when the Magnum it is mounted to "retires". The Magnum flies okay but is overrated IMHO -yes I have one, two actually, the second is spare parts but luckily not needed yet.. [8D] They do look fairly nifty though.
MJD is offline
