Balsarite problem
Reply
Old 04-30-2003, 03:36 PM
wuness
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Balsarite problem
I am getting ready to cover my Dust and was going to apply balsarite per the instructions. When I opened the can it looked thick and viscous and I thought it looked like trouble. It was. I only applied it to one elevon surface and it brushed on poorly and left little globs that had to be sanded off.
It was about 60 degrees when I applied it. Should it be warmer or does it need to be thinned? When I did a search, I found some other people had problems with it and someone suggested that Ultracoat doesn't recommend its use. What do you guys do? I don't plan on flying this plane all that fast with just an old OS .40, but I want to avoid any problems with the covering. Thanks.
wuness is offline
Old 04-30-2003, 04:25 PM
Blue Skyy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used to use it with good results for Monocoat. I receive a bad batch too one time and quit using it. Now I just do very fine sanding, vacuum to get all the dust possible off and then use a tack cloth. The results are just as good, without the expense or hassle when the batch is bad. Live and learn!
Blue Skyy
Blue Skyy is offline
Old 04-30-2003, 04:32 PM
deckerv
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I never really liked balsarite... if a little gets on the iron, it makes more of a mess to clean up.... IMO... Agree with BlueSkyy,,, sanding works best
deckerv is offline
Old 05-01-2003, 12:32 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use compressed air....and just blow off all the dust
particles before I cover.
Flyboy Dave is offline
