pusher jets
pusher jets
I puchased a pusher jet from nitroplanes.It is the kangaroo 40 size.I put a os max46 ax on it but I cant get it off the ground.the motor has the power with a 10 6 prop even tried a 10 7.The plane darts across the ground really fast but it will not lift off.I made a runway and it is very smooth.Could any one help with this.Thank you.
My Feedback: (98)
RE: pusher jets
Lengthen the nose gear, or move the mains forward so the plane almost falls on it's rear when sitting on the ground, sound like you're not able to rotate for lift-off.
My Feedback: (19)
OH
RE: pusher jets
ORIGINAL: austin197136
.... make sure you are installing the PROP the correct way. Curved surface and markings face "aircraft-foward".
And as noted, if it will not rotate...
1) check/search in RCU here for others with the plane. CONFIRM the CG location. The manuals are many times incorrect.
If it will not rotate at all it might be very nose heavy.
2) Nose gear/main gear location as noted.
My Feedback: (98)
RE: pusher jets
[quote]ORIGINAL: bob27s
That's exactly what my friend did on his Bobcat. I had forgotten about that.
