LR1 instructions/help?
Reply
Old 06-02-2008, 04:57 PM
Duane-RCU
Duane-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default LR1 instructions/help?
I don't have any instructions, maybe there are none for this.
Maybe someone can help.
What glue to use for the stabilizer, CA? That's what it said in the little info sheet that came with it, some info, but not enough.
And the slots are way too big for the supplied hinges. What should I do?
I see some mount the wing servos to the plastic covers with silicone, I'm thinking mount them in the bays, but with what/how?
What can I glue the servo tray in with?
Change to nylon wing bolts? What size?
And do I really want to bother with cutting the rudder?
I'm sure I'll come up with more questions as I go, but this will get me going for now.
Duane-RCU is offline
Old 06-02-2008, 05:53 PM
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: LR1 instructions/help?
I would E-mail WildHare and ask Tom or Patty if they have a copy that they would send you.
They are 2 of the nicest people out there. Or you could post the same question in the
Wildhare support forum http://www.rcuniverse.com/forum/forumid_355/tt.htm
someone may be able to help there also.
phjoker is offline
Old 06-03-2008, 12:44 AM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rudder is for sport flying. no rudder for speed. no gear for speed.
Install the stab the set i the plane verticle the put some oil on hinge pin very small amount. put epoxy in hinge gap on the stab slide hinge into slot wipe excess with tooth pick. then install the elevators.
I use a single 5/32 wire skid off the engine mount going back to a half circle near the leading edge.
my last one did 134 with OS 25 and 180-184 average with jett 35
airraptor is offline
