Eurotek engine will not stop running
Reply
Old 05-09-2003, 01:25 PM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Eurotek engine will not stop running
My Eurotek engine will not stop running when I close the carb completely....
Has anyone had this problem, and solution for this ?
This is costing me quita a lot of prop
Im not a glow engine master, and have only flown lots of electric planes, so all suggestins count
SJ.
SJN is offline
Old 05-09-2003, 03:49 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
make sure the seal between the carb body and engine case is good, while running, spray some WD40 around the carb, where is disappears is where your leak is
Cactus. is offline
Old 05-09-2003, 04:06 PM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
aahhh haaaa......exelent tip!
Ill try the WD-40 trick next time...
SJ
SJN is offline
Old 05-09-2003, 04:12 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey, we have MDS engines down here we know how to find a fix leaks, but.. West 50's do not leak..
Cactus. is offline
Old 05-10-2003, 12:33 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Press down the carb hard and then tighten the fixation nut... if you compress the O-ring enough all leaks should be gone (at least there...).
Rudeboy is offline
