f-4 phantom?
Reply
Old 05-09-2003, 10:55 PM
flyfree69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default f-4 phantom?
i finally got started on my f-4 , this may sound like a really stupid question but i can find the holes for the push rods i looked inside and out but cant find any place that looks like it should be cut out. has anybody else have this problem? or am i just blind ?any ideas??? thanks guys larry
flyfree69 is offline
Old 05-10-2003, 03:30 AM
FlooredCOBRA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
may just need to make your own holes for them. I found that the ones they cut out some times have a bind. If you make your own you can make sure if moves freely.
FlooredCOBRA is offline
Old 05-10-2003, 04:38 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hmm.. Lanier F-4?
You know, I don't remember- I thought there were some very small/light indents to make the cut- (I will keep thinkin' about it)
Make sure the CG is correct- I had to put my RX-Batt. AND some weight in the tail cones to balance her out with my YS-45...
If you do a search on Lanier F-4 (assuming this is the prop-jet you have...) There is alot of good info-
What engine you gonna run? Thought about B&D air retracts?
Anyhoo- Keep us posted,
james
Razor-RCU is offline
Old 05-10-2003, 04:57 AM
flyfree69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RAZOR i talked to you a while back about my f-4 but i was busy putting together a cessna for my girlfriend and learning to fly helis, now i can get started on my jet. the jet is a lanier and im running a rossi-45 larry
Old 05-10-2003, 05:24 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sweet-
Rossi-45...Good choice! Kinda heavy tho> so stuff that flight pack, back on the shelf by the elev. pushrod exits!
Everything else is pretty straight forward- Real nice ARF... I ended up glassing the base of the horiz. and vert. stabs at the fuse for strength...( not a have-to)
You have the mini-pipe or a full-on tuned pipe on the Rossi?
Let us know if you have any questions...
I put 3 more flights on mine just today! Lands slower every time...
Later,
james
