NEW ZOOMER/WITH JET 50
Reply
Old 07-15-2008, 11:22 PM
SACKRC
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NEW ZOOMER/WITH JET 50
GOT A ZOMMER TOGETHER WITH A JET 50 PUT A 8.8X8.5 APC FULL BLADE @ 19200.
1/4 OFF TIPS @ 20,000 RPM ON THE BENCH. WILL FLY IT WED. ALSO PUT THE EXHAUST TIMEING UP TO 170 (165 STOCK) USING 15% NITRO.. SEEM TO HAVE GOOD RESPONSE.
ANYONE HAVE AN OPINION ON WHATS BETTER, SPOILERS OR FLAPRONS OR NOTHING FOR THE BEST LANDING SITUATION. THANK RICH B.
SACKRC is offline
Old 07-15-2008, 11:40 PM
SPEED JUNKIE
My Feedback: (14)
SPEED JUNKIE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW ZOOMER/WITH JET 50
Zoom, Zoom, Zoom!
Sweet!
SPEED JUNKIE is offline
Old 07-16-2008, 06:21 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ailerons are well away from the wing tips, you may get away with flaperons. Try it way up high, worse case, slow & cross wind to see if it snaps easy.
freakingfast is offline
Old 07-17-2008, 11:40 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks nice.....
probably will not need flaperons.... but you can give it a try.
bob27s is offline
Old 07-17-2008, 04:48 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SACKRC:
Had the identical setup except no grinding on the engine. (A crime punishable by death) except the 12% wing. No problems in landing except it takes a little longer than a Q-500 to slow down. Mine died by radio failure at flight 15 or so. I liked it. If concerned about landing speed, try flaporons first at altitude. Can always switch them out if you don't like how they work at altituude. Does not take much!!! ENJOY
rmenke is offline
Old 07-18-2008, 08:11 AM
SACKRC
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WENT UP WED. A LITTLE HARD TO TRIM.. AFTER 4 FLIGHTS IS WAS FINE. HAD SOME HEAD WIND UP THE FIELD SO LANDING WERE SHORT. ON A CALM DAY MIGHT NEED FLAPRONS , OTHER THEN THAT IT EXCELLENT. LAST ONE I HAD WITH A 40 JETT DID 16O. THIS ONE IS NOT MUCH FASTER IF ANY. MAYBE MORE NITRO! TRYED SOME FULL PIPES ON THE BENCH. RPM IS ABOUT THE SAME AS THE JETT MUFFLER. I GUESS ILL HAVE TO TRIM SOME WING OFF..... OR ANY IDEAS OUT THERE ON A HOT PIPE , USING AND MAC 40-50 PIPE NOT MUCH DIFF. IVE TRY 30 % HELI FUEL NOT WORTH THE EFFORT , ONLY 500 RPM INCREASE. EXHAUST AT 170 MAYBE UP TO 175.????
SACKRC is offline
Old 07-18-2008, 09:53 AM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
get rid of the wheels and should pick up 15-20mph!!
airraptor is offline
Old 07-18-2008, 09:54 AM
ChrisAttebery
My Feedback: (15)
ChrisAttebery's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try the macs 45 sized marine pipe. Its got a shorter mid section than the airplane pipe. It won't have as smoothe of a transition though.
ChrisAttebery is offline
Old 07-18-2008, 11:28 AM
SACKRC
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I VE GOT THE WHEELS, GOOD IDEA DIDNT THINK IT WOULD BE A BIG IMPROVMENT.
WILL TRY IT THIS WEEKEND.. I DO HAVE A MARINE PIPE WITH BETTER ANGLES I KNOW THE RANGE WILL BE LESS MIGHT GIVE IT A TRY.
WHATS MY POTENTIAL SPEED??
JUST SOME TIME AGO A GUY FROM P. R. HAD A PATRIOT DOING 170MPH.
HOW TRUE IS THIS???? MY WEIGH IS 4.5 LBS. AND LESS AIRFOIL SHOULD I DUE 180 TO 190, 200????
MY FIRST ZOOMER DID 160 WITH A 40 JET, AND NO LANDING GEAR.
JUST A GOOD HAND LAUNCH??
SACKRC is offline
Old 07-18-2008, 12:15 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Timing change is not going to help a great deal .... once you get to a point, airflow through the carb/crankshaft becomes the limiting factor on the engine. All a timing change is going to do is shift the torque curve a bit.
You noted an 8.8x8.5 approaching 20K rpm.... thats darn good in any book. I'd not expect much more.
You might want to try taking a 8.8x9.25 and clipping it down in diameter to 8.25" to get the rpm back.
In any case, it is very unlikely the aircraft is going to perform much over 160 mph.
bob27s is offline
Old 07-18-2008, 01:46 PM
SACKRC
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BOB 160MPH ,, WHATS WITH THAT 170MPH GR PLANES PATRIOT VIDEO???? TRUE/FALSE.
SACKRC is offline
Old 07-18-2008, 03:53 PM
Stick40
Stick40's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HEY THER IS NO NEED TO YELL LOL, just kidding but thats a nice plane i hope you enfoy it. I would like to see some video though. Thanks
Stick 40
Stick40 is offline
Old 07-18-2008, 04:33 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: SACKRC
I'm not one to dispute anyone else's information. Any thing is possible.
In the case of the Rossi 53 powered Patriot I think the doppler speed measurements came up with basically the same info.
I only offer up information on my aircraft and a few others when I have confirmed in some fashion or someone has duplicated data. And from my own information I can sometimes offer estimates or projections for similar setups.
Keep in mind, full blown, current, competitive 428 Q-500 aircraft fly in the 170-175 range. QM40 tends to run around 185-190 now. Takes a great deal of attention to wing and airframe design, the right prop and a good load of power to get there.
bob27s is offline
Old 07-18-2008, 05:11 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: SACKRC
The 170 mph speed was measured in a steep dive. In level flight it hit 135 mph.
Mike Connor is offline
Old 07-19-2008, 05:16 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: SACKRC
Yo SackRC,
Please turn off the Caps Lock! It's harder to read caps and it is also a little bothersome, and it doesn't get the info across any better. Most forum users can't stand reading them.
Cheers,
MJD
MJD is offline
Old 07-06-2015, 12:45 PM
Kevin Matney
Kevin Matney's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look Great!!!!
Kevin Matney is offline
Old 07-10-2015, 02:29 PM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An 8 year bump. : o
dhal22 is offline
