props for Rossi .53
Reply
Old 07-31-2008, 07:33 AM
windcosmic
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default props for Rossi .53
Hi! I am wondering if the Rossi .53 could be run with QM .40 props..
windcosmic is offline
Old 07-31-2008, 09:29 AM
wjvail
wjvail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: props for Rossi .53
While I do own a Rossi .53, I've never run that small a prop on it. My understanding is that QM40s routinely turn 23,000+ rpm and I'm certain that even if the Rossi held up at these speeds, it was not designed for them. You might find good performance in the 18 to 19 thousand range but probably not in the 20,000+ range.
I which I had hard data for you.
Bill
wjvail is offline
Old 07-31-2008, 01:39 PM
YUKONFLYR
YUKONFLYR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi's do scream however the port timing is not set up to run in the mid 20k in rpm. It would spin the q40 ok but its timing might hold it back to about 21k or so.
If its timing were changed, then it would probably run just fine in the upper rpms, at the cost of a reliable idle...possibly.
YUKONFLYR is offline
Old 07-31-2008, 02:47 PM
windcosmic
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you all for the replies.. I will try.. Only hope to don't damage the engine
Old 07-31-2008, 11:26 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: windcosmic
The Rossi 53 is timed for torque, not rpm. A 9x10 or 10x8 prop would work well with that engine. I would think the QM prop would be horrible with this engine but maybe the light load would let it hit a higher harmonic tuning level and let it spin. Let us know what happens.
Mike Connor is offline
