What engine for kaos
Reply
Old 05-21-2003, 10:37 PM
coony2787
My Feedback: (33)
coony2787's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What engine for kaos
i was wondering in you alls opinion is the best engine for a 40 size kaos for speed , and just not terribly high in price ??? any input would be appreciated
Chad
coony2787 is offline
Old 05-21-2003, 11:53 PM
Dustflyer
My Feedback: (13)
Dustflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kaos speed
If I wanted to fly a fast airplane I would not be thinking about a Kaos. It's a pattern airplane. The last thing you want in a pattern or aerobatic airplane is speed; you want pull.
Want to go fast? Forget the Kaos. It is a magnificent design but was never designed for speed.
If you want speed start thinking about the airplanes routinely discussed on this forum or get involved in pylon racing.
Dustflyer is offline
Old 05-22-2003, 01:07 AM
coony2787
My Feedback: (33)
coony2787's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow you just bursted my bubble !!! the bad thing is i already have a brand new kaos sitting here . now i don't know what to do !!!
Chad
Old 05-22-2003, 02:53 AM
CONTENDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kaos
Chad,
Don't give up on the Kaos. I just finished one, am flying it with a Super Tigre (sp) 45abc, and am having a ball with it.
The thing is great for any type of weather, slows down to a walk for landings, and I have yet to stall it....just add power and fly on out of any problems.
However, if you have a Tower Kaos 40 ARF, be carefull when you build it....I found numerous problems including bad part fit, warped ailerons, poor tail attachment method...in fact I almost gave up on it.....but it was cheap, and flys great.
It' a great old design, and will be your favorite plane in no time.
By the way, any reasonable 40 or 46 will fly it. The Max 46fx would be a great choice, or the ST 45.
If you are looking for a great, cheap ARF for speed, try the Lanier Predator. It's a great quality ARF, only $120, it's FAST!!!!!, and easy to fly.
Good luck!
CONTENDER
CONTENDER is offline
Old 05-22-2003, 10:20 AM
Dustflyer
My Feedback: (13)
Dustflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Speed Kaos
Chad,
The Kaos is not a speed plane, but if you want to make it go as fast as possible on a budget just hang something like a Tower 46 on it. I owned and flew a kit built Kaos extensively for years and a 40 really is on the small size even for aerobatic or pattern work.
I had an OS 46FX on mine, from the sound of your post probably more expensive than you want to go. But I wound up putting an 11X5 on it to slow it down and give it more pull. An inexpensive but good running engine like the Tower 46 or GMS 47 with a higher pitch prop should do what you want. Try an 11X6, 11X7 or 10X8 and see what happens.
Old 05-22-2003, 11:30 AM
coony2787
My Feedback: (33)
coony2787's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well the reason i bought it was because back several years ago one of the guys at our club had kaos's and they sure looked fast back then . Maybe that was then and this is now . But the main reason i bought the kaos is because it has wheels and a rudder i want to guy fast but i like to make low knife edge passes about 3 foot off the ground at about 100 mph . and other maneuvers , so are you all telling me that i cant have speed and maneuverability ??
Chad
Old 05-22-2003, 01:15 PM
Dustflyer
My Feedback: (13)
Dustflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Kaos
You can have speed and manueverability with the Kaos, you are just not going to go anywhere near as fast as the planes generally discussed on this forum.
The Kaos is one of the all time great RC designs. It is also the basis for the Ultra Sport, which, as far as I could tell was a Kaos with a turtle deck. When I built my Kaos there was actually a die cut sheet of turtle deck formers in the kit that were not used.
The Kaos is a great flying airplane and a great was to get experience flying RC. Start out with a low pitch prop like an 11X5 and then go with an 11X6, 11X7, or 10X8 if you want to go faster. You might even be able to get away with a 50 in the nose if you don't mind spending a little more money. A 60 would be a bit much and kind of defeat the concept of the Kaos.
You will really enjoy the Kaos. Have fun with it!
Old 05-24-2003, 07:36 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The new .52 magnum xls at $100. on sale this weekend
will kick butt....
Flyboy Dave is offline
