an Idea for the leading edge
Reply
Old 09-15-2008, 05:18 PM
Dead Roman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default an Idea for the leading edge
I was thinking about taking some small strips of balsa and sanding the leading edge of the wing on my world models p-51 down to a much finer edge than is already in place. I figured this might cut the wind resistance down a bit. Am I crazy thinking this should work, would there really be any benefit?
Dead Roman is offline
Old 09-15-2008, 06:09 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: an Idea for the leading edge
ORIGINAL: Dead Roman
It may reduce the drag of the wing somewhat. As you sharpen the LE of an airfoil you generally tend to make the stall behaviour progressively more abrupt, so beware of that caveat. The frontal area of that aircraft has a lot to do with the total amount of drag, so the potential for speed gain may be so small you would wish you had left the airfoil alone.
Just things to consider. If anything, don't go too nuts on the LE.
MJD
MJD is offline
Old 09-15-2008, 07:58 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wouldn’t mess with the LE, if you are looking for speed think about fairings where the wing meets the fuse, clean gear doors, gap seals on the control surfaces, sharpen the trailing edges and maybe a retract tail wheel ( not much gain with the tail wheel). Or…… get an even bigger engine.
freakingfast is offline
Old 09-15-2008, 08:57 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As both who answered before said changing the leading edge will not help you much.
Your bet be is to clean up the airframe as noted sealing gaps, sharpening the trailing edges, retract the tail wheel, and alike, these are going to give you the best return for your effort.
Putting fairings on the control rod exits, along with fillets on the tail surfaces, may also help to reduce drag a bit.
I am no expert by any means but had asked some questions regarding a purpose built speed airplane a while back in the aerodynamics forum, you may want to see some of the replies from guys who deal with speed planes, as to what some of the secrets are...
More power....
lol
iron eagel is offline
Old 09-15-2008, 09:14 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The best of both worlds may be a sharp leading edge inboard and a rounded leading edge outboard. Would work like stall strips. However, most leading edge shapes are there for a reason and altering it may hurt more then it helps.
Mike Connor is offline
Old 09-15-2008, 09:49 PM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One more way to cut down drag is to clean up the air flow through the cowl. On my WM Dago Red I made the chin opening smaller, and added baffles around the cyl. and a fairing behind the cyl. to allow the air to exit more efficiently.
JMO but I wouldn't mess with the L.E.
proptop is offline
Old 09-16-2008, 11:53 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sharp leading edge is bad !!!
It does not help speed. You want the LE that provides the correct airflow over the airfoil used... that makes the wing work efficently.
Sharp LE = VERY pitch sensitive - the air can not decide which way to go for a very simply visualization.
Please do not confuse the sharp razor edges you may have seen on 1960s era fighter/interceptor aircraft as something related to speed. They were necessay for the supersonic flight environment. But they also caused take off and landing speeds that were WAY up there.
Models (and most aircraft) fly extremely sub-sonic.
The suggestions of others here will help you gain some speed. Get rid of drag where you find it.
bob27s is offline
Old 09-16-2008, 04:10 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: proptop
A rather big source of drag!
