Weston Magnum Internal set up
Reply
Old 10-13-2008, 10:47 PM
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Weston Magnum Internal set up
Im putting together my Weston Magnum and I was just curious if some of you could post pics of the inside of the fuse on yours. The instructions have the throttle servo on the balsa plate, but I would like to see where most of you are putting them. Not to mention battery positions, RX ect
Thanks guys!
please post pics or email me the pics
roneperez@stx.rr.com
thanks guys!
Dblex is online now
Old 10-14-2008, 08:06 AM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Weston Magnum Internal set up
Ron,
I recomend a search for Weston Magnum. There are several pages of info about how to set your plane up for sucess with diffrent engine and prop combos. If you don't turn any good stuff up let me know and I will try to dig some of the old threads back up for you.
vicman is offline
Old 10-14-2008, 01:17 PM
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I searched for a while last night...couldnt get the internal pics I was looking for.
Dblex is online now
Old 10-14-2008, 01:39 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not much to see really. The servos go in just like the instructions show. However to get the CG right you will want to cut a hatch further back. I'll take a look for the older posts after work when I have some time. I know Crazy4Flight took a bunch of his.
vicman is offline
Old 10-16-2008, 03:30 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put a Dub JETT .50 in the nose of mine.
To balance the Rx battery was behind the elevator servo.
I cut a hatch in the bottom of the fuse to install the battery.
throttle servo went where they made a pocket and I added a hole or two for the pushrod.
ID:	1053078   Click image for larger version
ID:	1053079   Click image for larger version
ID:	1053080   Click image for larger version
Crazy4Flight is offline
Old 10-16-2008, 07:25 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hay Crazy:
One of the clubs better "young guns" brought in a Weston Magnum for "Show & Tell" at our clubs meeting last night. It is the first one around, have never seen one fly.
During his naration, he admitted to purchasing the thing to kick this old man's tail. Being the kind soul I am I reminded him this has been a ongoing thing for the past four years, no cigar yet. Words led to words, so now its a race for pinks. I don't want to take a sword to a knife fight, but do not want to loose either. Accordingly, I need to know if the Weston Magnum will turn a pilon decently (using a Q-500 as a base). Am aware they will run in the 180's which is not a problem, but if it will turn, gonna have to take out my "Yellow Jacket" which is faster, and will turn. What do you think?? thanks, ENJOY
rmenke is offline
Old 10-16-2008, 07:51 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just what motor will he be using?
The magnum bleeds some of speed in tight turns...
so in a pylon race course it will fall behind in the turns.
Even my dog of a Viper, underpowered, carried speed thru the turns
youth and exuberance is no match for old age and treachery.
So hold the trottle back and sand bag the boy in the first heat.
Also the big canopy and thick trailing edges induce a lot of drag.
Having a fast plane is good.
Being able to fly it is better
Old 10-16-2008, 08:01 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rmenke
Hay Crazy:
One of the things they do most poorly in relation to a Q500 is turn - the wing incorporates nearly every design feature you could think of that contributes to wasting energy in tight turns. But appearance-wise the shape is somewhat cool, and most definitely plays on so many people's instinctive reaction to jet-looking models - "ooh, that must be fast..". If he tries to horse it too hard around the pylons and depending on his CG, he could even snap into the ground. On my first Magnum flight I snapped it on approach during the turn to final.. hmm, too much throw methinks.. but managed to recover just shy of the treetops and bring it in. That was a Tide moment. I subesquently reduced all the throws at every rate setting and was much more at peace with it.
If your airplane is even close to the same top speed, you ought to smoke his tail without too much effort. The fact that he thinks he can take you in a pylon race speaks oodles about what he thinks the model is capable of that it might not be.. but I wouldn't fall asleep at the joystick either if I were you.
MJD
MJD is offline
Old 10-16-2008, 08:46 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have both a 424 and a Jett .50 powered Magnum I think I would pick the same engine in a Q500 plane over the Magnum on course. We ran the Magnum past a radar gun at our speed rally and got 159 while a 428 plane got 181. Like the other guys said the Magnum aint not pylon job for sure.
just my .02[8D]
vicman is offline
Old 10-16-2008, 09:30 PM
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just finished mine today....
Throws on ailerons and elev as per manual?
CG ok as per manual?
Dblex is online now
Old 10-16-2008, 09:35 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
do a search on the magnum,
I think the manual's CG is might be wrong and it should be father back.
I used dual rates on elevator and 35% expo high rate on landing only
Old 10-17-2008, 08:46 PM
Dblex
My Feedback: (81)
Dblex's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shes finished, battery is behind the elev servo, but I cant get her to balance.
May have to add some weight in the tail
anyone have to add weight? she balances around 120mm...but little nose heavy at 130mm.
Dblex is online now
Old 10-18-2008, 08:37 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can see weight taped to C4F's plane. I taped some weight on the back of mine too. Small price for the grace you will pick up on landing and take off.
vicman is offline
Old 10-19-2008, 06:44 AM
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea I had some lead on the back of mine also.
phjoker is offline
Old 10-21-2008, 08:59 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: vicman
The lead weights were glued and screwed to the tail of my Magnum durring final assembly.
Do not trust the sticky back tape for external mounting.
The flat on the back of the fuse is the same width as the lead weights, GreatPlanes brand.
