Weston uk working on Mini MagnumR prototype
Looks like to take a hot 36 such as their powerhouse V1 and Electric version.
New twin 36v1 for massivive horsepower to go in bigger magnumR.......!!!!!!!!! Twin pipes howling in harmonics....Yerrrrrrrrrrrrr
Scroll down on page and you will see their prototype Vampire plane also, with enclosed tuned pipe, again powered by that screemin hot 36v1 single.
Westonuk sure love their speed the way they modify those webras
http://www.westonuk.co.uk/index_029.htm
RE: Weston uk working on Mini MagnumR prototype
ORIGINAL: mk1spitfire
MJD
ORIGINAL: vicman
I really like my full size Magnum and have wanted a 1/2a size for a while but haven't taken the time to scale one down.
Thx,
MJD
The Cyclon and Fora come with backplate mounts for 4 screws. I use #2 sheetmetal screws into 1/8" plywood. The firewall needs to be a 1 1/4" diameter circle with a notch in it to clear the exhaust stack.
I've thought about doing a 1/2A Vampire. The Magnum would be a great one to do a SWR with.
ORIGINAL: combatpigg
Oh no-o-o-o-o, not this one again... nope, just foolin'.
Okay, I can picture that but I don't know how to size the notch. What about firewall to prop driver face height? Any chance of scaring up those numbers? Ple-e-e-a-s-e[sm=kiss.gif]?
MJD
a.k.a. Mr. D
I've got a couple of project drawings that might help, but there's no substitute for having an engine in your hand to size things up with. I just attack the model with a "rasp bit" on a die grinder when it is time to clear the exhaust, then glass the gaping hole back up after the model is built. It helps to have a 1/2" thick balsa sub-firewall behind the plywood.
Yeah, I'd like to have examples of those engines but I don't for now.. all I have anymore are these lousy Italian speed engines [&o].
MJD
A chainsaw would be perfect! Why not just bolt a chainsaw directly to a workbench vertically and use it like 5 or 6 tools in 1?
I think you need to get moving with the OPS projects before we start fantasizing about 1/2A projects [>:]
Yes yes, I am working on the Whiplash speed trainer.. really.. and weather permitting I hope to fire up one of the .65's on the test stand this weekend.
MJD
Wonder how many millions of dollars of units they have sold compared to how many dollars worth of parts those Shop Smiths have ever produced?
A good place to start with a 1/2A Magnum would be 150 squares....about 30x 6 at the root and allow it to taper towards the tips. I think the Rifle is a slightly better looking plane. Almost the same plane, just a little bit more "believable" looking.
ORIGINAL: rmenke
CP:
Right on!!!! You are sure my kind of guy!!! Do you think that MJD is sort of getting cold feet??
CP:
CP - 150 squares? I'm talkin' about a squirts-and-giggles 1/2A Magnum, and yer talkin' about powered gliders. What gives? 9-10 ounces, 100 squares, something like that maybe? Wait I better check - with that silly wing, it might only have a 7" span.
MJD
MJD, 150 is a little bit doggy. The Outlaw is 124 sq in.. There was another SWR that was 105 and weighs 11 ozs.....pretty much the upper limit for wing loading.
Besides running 4 bolts and a header mount into your Whip, [2 hours for a union mechanic] don't forget your main assignment for this winter.......the 220 mph ME 163!!! As keeper of the OPS .65s, this is your destiny [8D]!!
And wait a minute.. I thought I was supposed to finish the pulsejet this winter? Goodness me*, lookit all the projects, what's a fellow to do?
MJD
* that's not really what I would normally say, but I must abide by the rules.
I took all that other stuff into consideration, that's why I gave you 2 hours instead of 1. I would seriously reconsider cowling the whip until after you fly it, it might end up being a waste of time. The plane will let you know after you fly it if it deserves the extra attention [and weight]. It does look like the engine will need to be shoved back. If you've got questions you could contact Chuck Auger at one of the other forums.
My Feedback: (13)
CA
CP:
Are you sure all had a proper direction in the first place? Us-n older guys seem to have a slight tendancy to become a little more critical as the years go buy. That twin boom thingy has given rise to some inspiration, picture a 90 OSVRDF upright, pipe extending to the tail, 10 X 9.5 or 10 CF prop singing around 24,000, retracts with doors. Bring on the quickees and rifles!!!! MJD, you gotta realize we jump your case with honest affection for our fellow man just because you are so much fun to jump on!! Buy the way, did anyone tell you that that OPS is a cranky nasty, hatefull thing that loves to hydraulic lock, sling props and plugs and challange your knowledge of all internal combstion engines???? Mine has the piston skirt cut down, crank rod and shaft lightened, OSVRDF carb and other modifications, where the combinations therin appear to be a bomb looking for a place to go bang. It sets in the motor cabinet gathering dust after loosilng favor to my Jett 60LX, and OS91VRDF, a case of love at first flight. OMG, her song is inspirational to all that has a mechanical soul. A honest offer. If you have problems with yours, let me know and will send you my beast, prop and pipe. You return whats left after she pulls the wings off what ever you get the guts to stick the thing in. Don't think you can really hirt these things much. Would love to hear/see your reaction to pilotilng something scooting in the 200mph range. Don't blink, concentrate on keeping it in close, have someone close by to help you trim. Don't take your eyes off the thing or it will be gone. It is a experience only a few will ever have and one you will never forget. ENJOY
ORIGINAL: rmenke
Bring on the beast. I am looking forward to this speed airplane thing with "glee and anticipation". Sometimes modelling activities just go status quo for a while, so it seems to me anyhow, and then once in a while you take a sharp turn in some other direction. They're pretty much all good directions (the jury's still out on lekkies..), so how can you lose? I think I can handle this sort of aircraft, but I am by no means complacent towards either the engines or the prospect of flying them. I've been working up to it. Besides, I figure enough other folks can fly 'em, I can too.
I nearly have my good flying buddies educated to STFU (you can figure that one out.. ) when I am flying fast stuff, they seem to think I don't need to concentrate sometimes.
Now, as to that monster you have lying dormant in your cabinet waiting to be fed fuel, that's quite an offer. That engine belongs in the nose of a nicely finished Strega.. [>:]. I'll video my efforts at running and setting up one of the .65's. My son will be eager to help in the hopes of catching a shot of a finger flying off in midair. I am BTW really itching for those Stregas, one of those honkin' low down the field with the gear up and doing 200+ on a howling .65 should be enough to wake the dead. Sounds like fun anyhow. At least I have about 5 months to plug away at these fantasies now.. sigh.
MJD
