egine for sig wonder
Reply
Old 12-10-2008, 06:12 PM
joeman784
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default egine for sig wonder
i dont no what engine to put on a sig wonder im building... help me
joeman784 is offline
Old 12-10-2008, 06:27 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: egine for sig wonder
ORIGINAL: joeman784
I don't know what engine to put on a SIG wonder I'm building... help me
Well what do you have???
OS.10FP OS.15FP OS.15LA will keep it light great for "low and slow" flying.
OS .20FP and .25FP will get a little more zip.
OS .15CV performs well
OS .25FX whips around the patch very well.
OS .32SX for going nuts
Jett .30 FIRE for going ballistic!
Yep, I even kit bashed a Woner into a twin. Two O.S. .15 FP
ID:	1087328   Click image for larger version
Crazy4Flight is offline
Old 12-10-2008, 06:35 PM
joeman784
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
all i have at the moment is a thunder tiger .15gp
Old 12-10-2008, 06:51 PM
aussiesteve
aussiesteve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are such a wide range to choose from - what choices do you have in a 0.15 to 0.25 glow?
I've had everything from OS 0.15 to OS 0.25fx in them - the 25fx was alittle heavy but ballistic
aussiesteve is offline
Old 12-10-2008, 07:02 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: joeman784
It will fly well, simliar in power and weight to the OS .15FP
servos: I used:a Hitec: HS425BB for the ailerons HS-81 throttle HS-85MG elevator.
I alter the build of the kit, to bolt the stab down to the fuse not glue it and eliminate the servo access hatch.
I put both elevator and throttle servos aft of F-4. under the stab. a longer throttle cable will be needed.
a 4 oz. slant nose Sullivan fuel tank will fit and you can fly a long time on it with your TT .15gp
Old 12-10-2008, 08:13 PM
joeman784
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
k so should fly around 50 60mph
Old 12-10-2008, 08:16 PM
seanucd2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one with a 15 LA that does about 85 (edit: from a radar gun). It's a blast to fly, and probably the most fun one could have with three ounces of glow fuel.
Also have another one nearly finished with a 25FX, but it's been hanging on the wall waiting for me to finish for a while now.
seanucd2000 is offline
Old 12-10-2008, 08:30 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: joeman784
60-70 + but it small size makes it look faster, it will be very agile too.
Old 12-10-2008, 08:40 PM
iflyg450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used an OS 25VF-DF Great combo
iflyg450 is offline
Old 12-10-2008, 08:44 PM
joeman784
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what about an os 25 fp
Old 12-10-2008, 09:29 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: joeman784
better than the .15
but if you have a .40 FP carb it fits the .25, install it! the 40's carb has a larger bore, also remove the baffle from the muffler
Old 12-11-2008, 09:46 AM
06sportster
My Feedback: (7)
06sportster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am still covering my Wonder, I bought a new OS 15CV-A for mine. It is going to be a lot of fun once I am done!
06sportster is offline
Old 12-11-2008, 11:48 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your .15 is just fine and it will fly well. If you want to put more horsepower on it later, then go for it! But for now why not just use the GP? If you're gonna buy a motor for more get up and go, well then, .25 and up IMHO.
My two bits.
MJD
MJD is offline
Old 12-11-2008, 04:42 PM
joeman784
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im stuck on step 5 what peice of wood do i put down... so confusing
Old 12-11-2008, 07:28 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
step 5 ??? cant find my old assembly manual
but take a moment and find the TE trailing edge stock...then scan forward thru the manual and they tell you cut, notch, out some of the TE between the cap strips for the torque rods.
Well look at the plans and your stock and cut 2 notches that will be the clearance for the torque rods. No carving later!
Old 01-02-2009, 03:25 PM
rtn9105
My Feedback: (35)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can anyone give the CG location and control throws for the Wonder?
rtn9105 is offline
Old 01-02-2009, 04:04 PM
Flyboy76
My Feedback: (14)
Flyboy76's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I watched a gentleman fly one last spring at a funfly. It hat the OS32 in it. Did that thing RIP!!!! Wicked fast so agile and would glide and glide and glide.
That is what i would put in it if i had one.
Geoff
Flyboy76 is offline
Old 01-02-2009, 04:11 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rtn9105
cant find my book off the top of me head:
CG 2 3/8" back on the main spar to 1/4 " forward
ailerons +/- 1/4" low rate +/- 3/8 high rate
elevator +/- 5/16" low rate +/- 7/16 high rate
Old 01-02-2009, 04:17 PM
Crazy4Flight
My Feedback: (540)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
– If you need more information, use these Sig resources –
E-mail: mail@sigmfg.com
Web Site: http://www.sigmfg.com/
Phone: 800-247-5008
Postal Address:
Sig
401-7 SOUTH FRONT STREET
PO BOX 520 #10682
MONTEZUMA, IA 50171
Old 01-02-2009, 07:14 PM
rtn9105
My Feedback: (35)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info. I checked the Sig web site but they don't offer the manual online. I also tried to call them but I got a machine saying they were unavailable.
rtn9105 is offline
Old 01-04-2009, 06:42 PM
Erik van Schaik
Erik van Schaik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CG 2-5/16" and 2-7/16"
No high rates printed in the manual.
good luck,
Erik
Erik van Schaik is offline
