glassing the patriot nose
Reply
Old 06-02-2003, 04:38 PM
patriot21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default glassing the patriot nose
i recently had a mishap with my patriot. the nose area was busted up a little bit. right now the fuse is painted with top flight paint. i was thinking about glassing the nose area to reinforce it. what combination can i use and what would be the best procedure. also anyone else have any other ideas
dave
patriot21 is offline
Old 06-02-2003, 10:49 PM
tkigar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check with Razor........He knows alot about the Patriot Jet From Great Plains, I think there were a few other threads on here about re-doing the front nose/cowl area. Tim
tkigar is offline
Old 06-03-2003, 11:36 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default patriot21....
....Check here....
http://www.rcuniverse.com/showthread...623&forumid=63
There are other techniques as well....like Sig Koverall,
....doped or painted on with polyurathane and such.
......Rev on my Brothers....... D
Flyboy Dave is offline
Old 06-03-2003, 03:38 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ouch!
Try .75 oz. glass and use either Z-Poxy (Premixed stuff..) or mix regular Epoxy and rubbing alcohol- mix the epoxy as you normally do, then add a tad of rubbing alcohol- just enough to make it milky...
You can apply it with a clean paint brush, a sponge, or a latex glove (I usually tack the edges down with fast ZAP so it does not move when epoxy mix is applied..)
Remember tho- the more alcohol you add, the longer it takes to cure- I usually let it sit overnight-
Hope this helps!
james
Razor-RCU is offline
