Way cool, I want some!
Reply
Old 01-19-2009, 11:46 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Way cool, I want some!
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVEU1]Eagle Tree Micro Airspeed Doohickey V3 [/link]
I had no idea these were so small, and not that expensive.. cool............
MJD is offline
Old 01-19-2009, 11:55 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Way cool, I want some!
But don't you need one of thes to go with it?
http://www3.towerhobbies.com/cgi-bin...&I=LXTNL3&P=ML
soarrich is offline
Old 01-19-2009, 01:20 PM
still4given
still4given's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not according to this.
http://www.eagletreesystems.com/Stan...standalone.htm
still4given is offline
Old 01-19-2009, 01:49 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: soarrich
It indicates you can read from the built in display as a standalone unit, either the altitude or speed version:
- Our tiny new Airspeed and Altitude MicroSensors have two modes: they work standalone with no additional equipment required, as well revving up your eLogger and PowerPanel LCD for full data logging. These precision instruments use pressure differential to measure Airspeed or Altitude.
For standalone mode, simply plug the sensors into a spare receiver channel or small battery (3V to 16V) and fly your model. Then, when you land, your maximum altitude orairspeed will display on the built-in 7 segment LED. For example, if you flew to 281 feet, the unit will display “2 – 8 - 1” repeatedly. No configuration, additional equipment, or computer required! -
MJD
MJD is offline
Old 01-19-2009, 01:53 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They will give max airspeed, but that is about it. If that is what you are looking for, have at it.
If you are flying a plane off a grass run way, I would suggest putting the pitot tube in the RIGHT wing. If you put the tube on the left and your prop cuts any grass, it can clog the tube as the prop slings the grass to that side of the wing.
We have been testing the real time setup pictured above, it is pretty cool, but the smaller unit would work fine if you just wanted to know your top speed.
daven is offline
Old 01-19-2009, 02:15 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks cool!
the only problem i can see is TH don't sell the extra pitot tubes for the install to work on several planes...
vasek is offline
Old 01-19-2009, 03:57 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I pitot tube is just very small brass tubing, I can't remember the exact size, but it was somewhere around a 1/16" I.D.
We measured it, and then just bought some more.
No biggie
daven is offline
Old 01-19-2009, 05:11 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: daven
No biggie
Dave, in the pic there seems to be on one end of the pitot tube two smaller tubes in Y shape.
How did you replicate that?
vasek is offline
Old 01-20-2009, 07:07 PM
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: vasek
looks cool!
Check out this page and go about 1/2 to 3/4 of the way down. They do offer additional pitot tubes for $9.99
http://www.eagletreesystems.com/Pro/pro.htm
phjoker is offline
Old 01-20-2009, 07:15 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Our system was not set up that way. The brass tube only had one end that hooked to the unit, and the 2nd line ran to a static tube that is mounted withing the fuse with a couple small holes drilled trough it, with the end plugged.
They must be doing something different now.
We had very accurate readings compared to a radar gun, so I was quite confident with the data.
daven is offline
Old 01-20-2009, 10:19 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: daven
It's a pretty cheap and easy to use way to get bragging rights, mind you top speed in a dive is all you will get unless you stay farily horizontal. I didn't notice if you could reset it in the air, in which case that would be cool to give control of when to read.
MJD
MJD is offline
Old 01-20-2009, 10:54 PM
forsakenrider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could always hook a 3.7 gram servo up to a switch that powered the unit, then flick it on after the dive.....
forsakenrider is offline
Old 01-21-2009, 02:37 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The one I got was about $10 less and it was made [IIRC] by Winged Shadow Systems. After the plane lands you wiggle your finger quickly past a photo diode, then it gives you a flashing readout in decimal code. They are a great addition to the hobby.
combatpigg is offline
