Pusher Prop for TH .75
Reply
Old 03-09-2009, 01:10 PM
Piddler
Piddler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pusher Prop for TH .75
Need recomendations for a pusher prop on a Tower Hobbies .75. It is on a Balsa USA Enforcer. I've read a few post that say 11x6 or a 11x7 pusher. The manual suggest a 12x6 or 13x6. Why are some using the 11x6 or 11x7 for the pusher? I am totally new to pusher props.
Piddler is offline
Old 03-09-2009, 03:19 PM
AGR413
AGR413's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Pusher Prop for TH .75
Of all the props I have tried the 12x6 zinger pusher makes the most thrust and gave the highest top end. The downside is they succumb to pebbles or landing bounces very easily, so much so that I use an 11x7 apc. I would love to try an apc 12x6 pusher if there was such a thing.
I just sent APC an email asking them to consider making a 12x6, 13x6 for engines like this, there are many popular airframes these days flying .75 engines which could benefit from these. We shall see.
AGR413 is offline
Old 03-09-2009, 05:42 PM
Piddler
Piddler's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you, that answers my question. I will send a letter also. I just ordered two of the Zingers before I got your response. I already have the APC 11x6 and 11x7.
Thanks again.
Piddler is offline
Old 03-09-2009, 06:43 PM
still4given
still4given's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had good luck with the Graupner 11x8 Pusher.
still4given is offline
Old 03-09-2009, 10:04 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: still4given
Yeah, that would be my suggestion too. Very good prop.
bob27s is offline
Old 03-15-2009, 05:39 PM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Piddler
I have a TH .75 and tested APC 11 x 7p to turn 14,700 rpm. However I was unable to set the low speed needle to run clean at idle. The 11 x 7p did not appear to load the engine sufficiently.
The only 12” pusher props that I found were wood. I ordered a Graupner 11x8 Pusher to try. If the 11 x 8 doesn’t load the engine a 12” prop will be next. Unfortunately with 12” diameter props the Bob Cat will have ground clearance problems.
Bill
BillS is offline
Old 03-16-2009, 07:48 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BillS
"I ordered a Graupner 11x8 Pusher to try. If the 11 x 8 doesn’t load the engine"
Bill
With a heat gun and a pitch gage (home made pusher gage) you can tweak the Graupner 11X8 to 11X10 easy.
11X10 pusher
http://www.zingerpropeller.com/3_bladed_Propeller.htm
OR
11X7 -3 blade pusher
freakingfast is offline
