STARTING STAND FOR A NO WHEEL PLANE
I know the SIG Wonder is not an Extreme Speed Plane but its design is similar to some that are. I found it unhandy to try to hold and start it and then pick it up for launch. I built a simple starting stand that can be clamped to the edge of a table. After starting, just remove the plane from the stand/holder and go. Now I can start and launch it safely by myself.
RE: STARTING STAND FOR A NO WHEEL PLANE
ORIGINAL: airbusdrvr
I know the SIG Wonder is not an Extreme Speed Plane but its design is similar to some that are. I found it unhandy to try to hold and start it and then pick it up for launch. I built a simple starting stand that can be clamped to the edge of a table. After starting, just remove it from the stand/holder and go. Now I can start and launch it safely by myself. Here is the link to the pics in the Tips and Techniques section of RCU. http://www.rcuniverse.com/forum/m_8687542/tm.htm
MJD
Alternatively, use a fruit cardboard box with 2 cut outs for the front and back of the plane. That works well, I seen them use on up to 40 sized planes. Cheap and folds flat!
