Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
STARTING STAND FOR A NO WHEEL PLANE
Old 04-16-2009, 05:20 PM
airbusdrvr
Default STARTING STAND FOR A NO WHEEL PLANE
I know the SIG Wonder is not an Extreme Speed Plane but its design is similar to some that are. I found it unhandy to try to hold and start it and then pick it up for launch. I built a simple starting stand that can be clamped to the edge of a table. After starting, just remove the plane from the stand/holder and go. Now I can start and launch it safely by myself.
ID:	1181568   Click image for larger version
Old 04-16-2009, 09:30 PM
MJD
MJD's Avatar
Default RE: STARTING STAND FOR A NO WHEEL PLANE
ORIGINAL: airbusdrvr
I know the SIG Wonder is not an Extreme Speed Plane but its design is similar to some that are. I found it unhandy to try to hold and start it and then pick it up for launch. I built a simple starting stand that can be clamped to the edge of a table. After starting, just remove it from the stand/holder and go. Now I can start and launch it safely by myself. Here is the link to the pics in the Tips and Techniques section of RCU. http://www.rcuniverse.com/forum/m_8687542/tm.htm
That's a handy little stand you've made up there, good idea to post it here.
MJD
Old 04-16-2009, 09:39 PM
tIANci
tIANci's Avatar
Alternatively, use a fruit cardboard box with 2 cut outs for the front and back of the plane. That works well, I seen them use on up to 40 sized planes. Cheap and folds flat!
