Outlaw Speed Run
Old 05-02-2009, 08:53 AM
ArthurD
Default Outlaw Speed Run
Mark,
You still out there? Sure hope so, because I've made a few changes to my Outlaw since we last talked. Sound recordings of several flights were made and I want you to turn them into speed readings for me. You mentioned something about having a computer program, Wave-a-Scope or something like that. Can I send you the file and have you run it though your computer?
Old 05-02-2009, 04:51 PM
gofastz
gofastz's Avatar
Default RE: Outlaw Speed Run
Arthur,
Send it to me!!!!!!!! So you think your going to De-throne me and my Diamond Dust.......Ha! Bring it on Baby!!!!!
Old 05-02-2009, 05:59 PM
ArthurD
Okay, I've PM'ed it to you. You'll be sorry you spoke so harshly!
Old 05-03-2009, 08:25 AM
evan-RCU
evan-RCU's Avatar
You guy's are funny....
Old 05-03-2009, 01:15 PM
ArthurD
Actually it isn't THAT funny. He'd like nothing better than to blow me away like he's been doing for the last few months and I'm getting a little tired of it. Now, after a lot of work, there's the chance of 'cleaning his clock' using his own speed-from-sound program as the scrub brush. HA! Can't wait to see if he has the guts to answer publicly.
Old 05-03-2009, 01:58 PM
combatpigg
combatpigg's Avatar
The slower one of you two guys should have to perform a duty for the other guy until the tables get turned....like a weekly car wash or lawn mowing. Imagine how fast your planes would be flying after a couple of year's worth of this kind of rivalry?
Old 05-03-2009, 02:00 PM
Strykaas
I was not expecting that while I was reading the beginning of the sentence... [X(]
Old 05-03-2009, 03:19 PM
gofastz
gofastz's Avatar
Arthur,
Ok, ah this recording you sent.......Let me see if I understand.... Cause I can't believe it....This is the outlaw I watched you fly a couple days ago...You and Joe were recording passes? The Outlaw with a 36 webra , Header and pipe , ceramic bearings , new crank shaft? Is this pass that plane and motor? I just can't believe it's so...... Is it!!!!! Gofastz (Mark)
PS Those air flow changes to the rear rudder and nose can't be making this much impact on you speed......NO WAY!!!!!!
Old 05-03-2009, 03:29 PM
ArthurD
I knew you couldn't admit it. Go ahead, get humble, delcare me the fastest. It's your program, your computer, your recording! HA and HA HA!!
Old 05-03-2009, 04:02 PM
Strykaas
We want pictures of these modifications. This is a must !
Old 05-03-2009, 04:11 PM
cncswiss1
well ? you gonna share vid and numbers?
Old 05-03-2009, 04:17 PM
evan-RCU
evan-RCU's Avatar
No way a Outlaw is faster than a DD since a Outlaw can fly with a .36 tops and a DD a .50.....
So whos going to spill the beans and what's the speed?
Old 05-04-2009, 07:33 AM
ArthurD
What's the number, Mark? It isn't that hard; the computer does the work.
Give it to us in MPH; knots looks slower.
Old 05-04-2009, 08:43 AM
gofastz
gofastz's Avatar
Arthur,
All I got to say......Terrific!!!! And from a 36 no less! Congrats Arthur! They were nice level passes, too....... Gofastz
ID:	1192049   Click image for larger version
Old 05-04-2009, 09:48 AM
Mike Connor
Mike Connor's Avatar
Something is not right here. Could you post the video for others to see and examine?
Old 05-04-2009, 09:52 AM
combatpigg
combatpigg's Avatar
170 mph is remarkable! I wouldn't have believed it without proof.
This is about 40 mph faster than what I would think is possible.
Old 05-04-2009, 10:23 AM
evan-RCU
evan-RCU's Avatar
No way... it would take a JETT .50 or nelson .40 on an Outlaw to do this.
Old 05-04-2009, 11:44 AM
ArthurD
For all of you who doubt the results of the computer program and want furthur proof..................
Send me your video camera. I'll shoot a flight and return it to you. I don't have a video camera.
Or, examine the audio recording for yourself and see if you can discredit it. I'm happy to admit it if I'm wrong.
Better yet, come on down to Florida and I'll show you first-hand.
It's little wonder that you think it's speed is impossible to be correct. I wouldn't either except it's obvious to me and many observers that it's the fastest thing they've seen. We have several other models tested using the same technique of measuring speed and they are obviously slower, mostly in the range of 120 to 150 MPH. So, either all the models are testing wrong or none are.
Come on down!
Old 05-04-2009, 11:51 AM
combatpigg
combatpigg's Avatar
What size prop did you do it with? I've been talking with another guy in the tachometer forum about this engine and were speculating which prop to use.
Your Outlaw is 10 mph faster than my Webra .50 powered Diamond Dust running a 9x8.
Old 05-04-2009, 12:07 PM
ArthurD
The prop is a APC 9X7, fuel is PowerMaster 10%, header is a Mac's cut to about 60MM from the weld, glow plug is an OS R5, bearings are Boca Bearings ceramics, all trailing edges are trimed sharp, rudder servo is internal with the push rod very close to the fuse and a small solid aluminum spinner.
Old 05-04-2009, 12:11 PM
combatpigg
combatpigg's Avatar
Thanks for the info Arthur. I've been meaning to get an Outlaw.....it's been awhile since I've done any flat spins with a delta.
Old 05-04-2009, 12:28 PM
Mike Connor
ORIGINAL: ArthurD
Where is it? Audio without video however is not proof of wind conditions or aircraft attitude. Actually I am waiting for someone to say it is a joke.
Edit to change "level flight" to "wind conditions".
Old 05-04-2009, 12:30 PM
ArthurD
You're welcome. I'v been so busy enjoying the speed I've never tried to do spins. Thought about it, but not done it. Come to think of it, there's really not much reason to have a rudder and it's hardware unless you like spins. Maybe save weight and leave all that stuff off?
Old 05-04-2009, 12:33 PM
Mike Connor
ORIGINAL: combatpigg
Proof?? You are kidding, right?
Old 05-04-2009, 12:35 PM
ArthurD
No joke, Mike.
Do you think the audio can be faked or is not accurate? Take a look at the program results and see if you can make them say anything other than what was reported.
Come on down. Tulsa's way to hot in the summer anyway.
