OT/ Need aero help
Reply
Old 05-05-2009, 01:36 PM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OT/ Need aero help
Hey guys.... as you can see below this is not an airplane but it wants to fly like one. At higher speeds it likes to lift the front sponsons and the large surface area is acting like a kite. I need your help with tring to slow the flow of air on the top deck so the nose won't lift. Or other suggestions would be nice.
Quick flip
ID:	1192788   Click image for larger version
asmithnc is offline
Old 05-05-2009, 01:42 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OT/ Need aero help
ORIGINAL: asmithnc
Quick flip
Unless this is an unfinished version, I think you need to spoil the airflow, as right now you have a huge flate plate and no wonder it is lifting. What about experimenting with some triangle stock or some kind of fence on the leading edge of the deck? Is the deck at some kind of angle of attack at speed?
MJD
MJD is offline
Old 05-05-2009, 01:49 PM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
First you have the engine too far rearward! This makes the C of G critical at high speeds and the front lifts suddenly, making the whole thing flip over!
Second put a wing up front! Like on a Formula one car to get down force!
jaka is offline
Old 05-05-2009, 08:07 PM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your input.
First I would like to say that this boat (kit) was never designed for this much power or speed. I guess that why I'm doing it.
Second the engine will go on another boat designed for higher speeds.
Since I can do nothing on the engine placement I need to look into aero. I'm a machinist and thought this problem would come up so I made spoilers. I forgot I had them until the F1 wing thingy came up (Go WEBER). Will they work or do I need to make something else.
ID:	1192971   Click image for larger version
asmithnc is offline
Old 05-06-2009, 09:40 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Looks Ok to me! But see to that you make it (them) adjustable
jaka is offline
Old 05-06-2009, 11:20 AM
asmithnc
asmithnc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jaka
Hi!
Thanks and yes I did think about it. LE add washer for higher degree and TE you can also add washer for more air flow.
After watching the video I did notice the angle of attack is bow high. I will also make add on rear sponsons to raise the bow to lower the attack on the bow. I'll just do one at a time to see what works.
asmithnc is offline
