Screamin Demon / Lickety Split build
Reply
Old 05-13-2009, 10:22 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Screamin Demon / Lickety Split build
I figure I had better assemble a handful of these things for myself, and here are a few shots of my "prototype" slowly coming together. I must confess I like the looks of the tip fins far more than the traditional stodgy center fins. I really should toss the OS .46 in there for pilot calibration flights, then out with it and in with the West or Jett .50. So far what you see here - engine, airframe minus a bit of hatch but mroe than you see here, battery - is about two pounds. Still a few things to go but I'm tired so not tonight.
MJD
MikesRC
ID:	1197667   Click image for larger version
ID:	1197668   Click image for larger version
ID:	1197669   Click image for larger version
ID:	1197670   Click image for larger version
ID:	1197671   Click image for larger version
ID:	1197672   Click image for larger version
ID:	1197673   Click image for larger version
MJD is offline
Old 05-13-2009, 10:42 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Screamin Demon / Lickety Split build
That looks great MJD! The different camera angles make it look like 2 different planes. I wonder what tip fins do to the roll rate? I'm sure this has been covered, just don't remember what the findings were.
Having a "slag engine" laying around for flight testing isn't a bad idea.
combatpigg is offline
Old 05-14-2009, 12:12 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: combatpigg
In the production version first run I added side mount servo cutouts in the center ribs, just a hair ahead of the rear spar. The opening is sized for minis - HS225's actually - but you can even lay standard servos on there side in there and have only a bit of the servo arm protrude. On this example a Dremel tool substituted for the laser. Now, with axial motion only due to the side mounting, it is easy to make a skinny aero fairing over the linkage.
I like this fin arrangement a whole lot more than the "traditional" boxy center fins. Looks nasty. Looks like a scaled up version of something you'd build in three minutes flat for a Fora.
I found to my delight and surprise that my Doylejet pulsejet, which is heavier than a Dynajet though internally identical, weighs nearly exactly the same as the West .50 and pipe pictured here. Silly me, I was worried about weight.
MJD
MJD is offline
Old 05-14-2009, 10:11 AM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To my surprise, it was hard to tell the difference between any flight characteristics when winglets were used. I like the looks of the winglet shape and was considering putting a tab on them so they could also be used as inboard fins. That would keep the laser cutter from cutting two sets of fins.
Mike Connor is offline
Old 05-14-2009, 10:49 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Mike, that's what I thought you said about it. I like both styles, but my next delta will definitely have the tip fins.
The guys who come here looking for a fast ARF [and who claim that they can't build ] should take a good look at this plane take form. The most challenging part of a build like this might be doing a nice covering job, but this is the ideal plane to learn about and practice covering with. You could do this whole plane with a household iron, I don't recall if 1 roll will do the whole job or not on a plane this size. The end result for a first time builder will be a plane that doesn't take weeks and weeks to complete, the entire building sessions could be broken down into :
Framing with wing tips installed and engine mount drilled, sheeting installed...3 hours
Elevons hinged, servos mounted, pushrod linkage assembled, fuel tank assembled...3 hours
Pipe mount installed, top sheeting and hatches installed, fiberglass wing tips, final sanding......3 hours
Covering and fuel proofing......
I've never kept close track of time, but I'll bet 9 hours is realistic to get one of these ready for covering.
Old 05-14-2009, 11:17 AM
mk1spitfire
mk1spitfire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
love to know what the overall weight will be with west and your speed ground/air
mk1spitfire is offline
Old 05-14-2009, 02:31 PM
BiggerDanno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like a plane that would look good in my hangar.
Got a ballpark price?
BiggerDanno is offline
Old 05-14-2009, 06:01 PM
Mike Connor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: mk1spitfire
I built 4 and they all came out around 2 lb 12-14 oz RTF (less fuel). Mine were with a 17 oz. engine and that weight included 2 oz. tail weight needed with the side exhaust. Some have reported no balance weight necessary with a long pipe. The speed will be interesting. I bet quick if built clean.
Old 05-14-2009, 07:38 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The West .50 V1 and pipe combo shown weighs 522 grams, that's 18.4 ounces, for reference. I have a Sport Jett .50 and it is a killer engine, but these have already flown on that engine so I decided to shove the West in it and see what happens. It looks snotty with the pipe hanging out there, though it also looks like a pile of drag. I expect it to outrun the Magnum however.
My all up weight remains to be seen, but I imagine I've managed to create a 3 pound ship the first go-around.
MJD
MJD is offline
Old 05-15-2009, 12:14 AM
smoknrv4
smoknrv4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lookin good!
I really enjoyed building mine, went together fast!
smoknrv4 is offline
Old 05-15-2009, 07:05 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: smoknrv4
lookin good!
No matter how simple something is to build, I always find ways to make it into a project.. My build time will be used as the an example of how long it can take.
MJD
MJD is offline
Old 05-15-2009, 02:47 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BiggerDanno
Whoops BD, forgot to reply on price! I am keeping the price the same as before @ USD $69.95.
I totally agree, it would look good in your hangar; and I don't even know what your hangar looks like. See, now you know you need one.. .
MikeD aka MJD
MikesRC
MJD is offline
Old 05-17-2009, 12:35 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, not doing too bad actually.
Everything on the scale minus covering/finishing and elevon pushrods sits at 2.75 pounds, aka 2 lb 12 oz. I wonder how much my finishing job is about to weigh..?
My reply screens have gone buggy.. the text box semi-disappears. ***?? I can only use this quick reply box below the thread.
MJD
MJD is offline
Old 05-17-2009, 02:39 AM
mk1spitfire
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe build something infront of header to streamline the dragcoefficeint round shape? More bullety??? Ha, The ultimate anti drag ship
Old 05-17-2009, 09:23 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Admittedly, the side exhaust layout totally sucks in terms of cleaning things up. I'm not going to worry about it on this model - the goal is just to build it somewhat conventionally, and bolt on an engine someone might have laying about looking for something to do. I imagine it should still move out fine as is.
In my case I dinged the LE of my Magnum, which would have taken me all of 30 minutes to repair, but I was bored of it so stripped out all the equipment. I thought it wuld beinteresting to drop the West .50 in one. I will be building a couple more of these deltas asap (hopefully more quickly than this one ) and will be messing with cowls and the like and different engine arrangements.
 In the meantime I've set the Magnum airframe aside but where I can look at it and think about a replacement.
MJD
MJD is offline
Old 05-17-2009, 11:30 AM
arcticflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MJD- You talked about replacing your Magnum....I just fixed mine after a turn two back straight flame out (too lean) minor damage didn't make it all the way back to the nice smooth runway. Anyway I got a Rifle from Angel last week. Took it out of the box just to look it over. It is not an ARF....but I didn't expect it to be. It is however ALOT nicer than the Magnum. I'm moving back to Canada the first week in June (Prince Albert) so I decided not to start on the project and put it back in the box....It is very, very, similar to the Magnum...but WOW is the wing straight! I am looking forward to your getting some of the kits done and will be ordering one when I get back up north....keep up the good work!
arcticflyer is offline
Old 05-17-2009, 11:42 AM
smoknrv4
smoknrv4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm contemplating a SJ 60 LX for mine and I've heard that Cool Power isn't the best thing for Jett engines, what about 15% nitro with a little added castor,  if so how much per gallon would you add?
So why isn't Cool power recommended I've always used it?
P.s. Is anybody else having problems posting a new thread?[]
smoknrv4 is offline
Old 05-17-2009, 12:55 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right now I can't post new threads, or reply to posts. The text box comes up blank. I can only use the quick reply box at the bottom. I thought it might have been at my end but perhaps not.
MJD
MJD is offline
Old 05-18-2009, 06:42 AM
Wiggy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
Ihope you get your posting issues fixed. Ilook forward to reading about your progress with the Screamin Demon. Ihave built numerous Diamond Dusts and look forward to building one of these. I know this is based on the DD design/construction method so it should be a quick and easy project.
Keep us up to date on your construction.
Wiggy
Wiggy is offline
Old 05-19-2009, 10:06 AM
BiggerDanno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: MJD
MikeD aka MJD
MikesRC
When will it be available?
Old 05-19-2009, 10:18 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
June 1 is the intended release date, and so far everything is on track. The site has occasional updates, and some work still to go before June 1: [link=http://www.MikesRC.us]MikesRC[/link]
Mike D aka MJD
MikesRC
MJD is offline
Old 05-19-2009, 01:23 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: smoknrv4
You can use CoolPower if you wish. It is a good fuel, and if you do not get the engine hot/lean it will run and last just fine.
You can add a touch of castor to it if you wish - just an oz per gallon goes a long way.
Most of us prefer to run a bit of castor in the fuel blend for the AACand ABCengines, so Omega, wildcat, PowerMaster all offer about at 16-17-18% total oil, with about 15 + 3 combination.
The 60LXis a "Bit less user friendly" than the other sport jett engines - which I define as, prop it incorrectly or if you miss the needle setting, it will remind you. Not difficult or criticle to operate at all, but I think you get the idea
bob27s is offline
Old 05-19-2009, 01:51 PM
lfinney
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looking forward to building one of these delta's and your idea for a laser cut assembly jig is  dead on for building straight airplanes
lfinney is offline
Old 05-19-2009, 06:28 PM
smoknrv4
smoknrv4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[/quote]
[/quote]
Thanks Bob for the info, instead of putting it in the Screamin Demon, I just ordered a Juno f-20 for it, I can't wait!!
Hey MJD,Its nice to see a fellow Canuck is supplying this great aircraft,when those kits are ready I'm going to order one, what kind of price shipped are we talking about CAD toLondon Ontario, I want to build another one with winglets this time.
smoknrv4 is offline
Old 05-22-2009, 07:16 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nearly done! Got the covering on, sprayed the tips in Insignia Blue, and will add some neon insets to the tips, and some blue large checkers to the white underside I think. My eyes need all the help they can get.
Only the tank protrudes, everything else is flush. You could fit two radio systems back there. AUW is still projected at 2.75 pounds, but we'll see where I screwed up once all the trim is done and ailerons mounted.
Mebbe test fly Sunday. More likely Tues-Wed.
And BTW, all the parts are on track - plywood parts all cut, balsa being done now. Yeehah!
Mike D aka MJD
MikesRC
ID:	1203815   Click image for larger version
ID:	1203816   Click image for larger version
ID:	1203817   Click image for larger version
ID:	1203818   Click image for larger version
MJD is offline
