Magnum, hauling ass VIDEO
RE: Magnum, hauling ass VIDEO
I don't know....
Idid fly the Magnum a few weeks ago though, it's a easy plane to fly, almost as easy as my electrics. That Weston .50 is one fantastic motor...
ORIGINAL: mk1spitfire
Ha.!
Is you twin outlaw coming out to play again this year?
Ha.!
http://www.westonuk.co.uk/index_133.htm
Alot of speed freaks love this model for its simplicity to get you fast with the recomended set up. I'm sure someone can guide you to a distrubitor in you area.
The above uk link I've given you might be of interest
ORIGINAL: vicman
Was that you in the 200 mph vid?
I've always doubted the 200 claim. Mine only ever got 160.
Evan the twin dust would be exciting at the rally this year.
Shame I stripped mine, would have been curious to clock it at the rally. Chances are there might be one there I guess.
MJD
MJD what are you bringing? One of your new buisness's products? Be nice to see. What do you mean stripped your magnum? Stripped the gear out for another project?
Had fun today Vic, thanks again.
ORIGINAL: vicman
You know there will be[8D].
The guys are looking forward to seeing you down here. I'm starting on this year's entry.
My glass wonder model might be bumped by a .65 delta, given that it would be somewhat of a prototype. And easier to finish in three weeks.
I'm looking forward to the road trip and tomfoolery myself! Spent too many years at rocket shindigs, time to hang out with airplane geeks again. Better check my passport is good..
MJD
My Feedback: (71)
I've always had trouble clocking my Magnum with Weston 50 motor in it. Difficult to fly it close and steady enough for the damn gun to lock on. I got reading of 137mph couple times but think it's a little faster than that. I bet anyone saying 200mph is only guessing at the speed. I'd like to see a youtube clocking of a fly-by before I will believe the 200mph quote.
ORIGINAL: kmtranmd
MJD
You gota go 8x10 to go real quick.,if you can launch it that is!!!
I spoke to weston about swan necking the the header and putting the pipe inside for less drag.. I THINK i saw someone had used a rear exhaust engine and do the same idea.
160 180 200 All is quick.!!!
They are testing the mini magnum now, with their hot 36v1 set up
I spoke with Alan at Weston UK last week concerning my West 50 that I returned due to a bad plating job in the liner. They fixed my engine no charge.
We spoke at length about tuning the engine as well as some of the projects that he is working on. One project I had seen on their website, which is no longer on the site is a pair of West .36's ganged to a gear drive (1:1) to turn a single prop. He said that this pair of engines made almost 6hp. I asked him what plane that it might be designed for, he told me that he modified the front of a MagnumR to accommodate this engine(s). I'm suspecting that the claim made of over 200 mph was probably with this engine in it rather than the .50 Notice on the site that the 200 mph claim does not refer to a particular engine, though it's inferred that it's the 50.
The claim was made before the twin engine prototype.
Though the claim could also be interpreted as ground speed.!!
I must get around to tryingto putanairspeed monitor on it.Even a no wind day the air and ground speed will be the same. The vertical dive is another variable and of course your style of flying.
Fly itVERY high and vertically drop it pullingup GRADUALLY as not to loose speed near the ground for a 50meter passthen up to feel its speed, Even better downwind.
I've got a shim to try and will up the nitro
"The claim" may also be based on a nanograpph. RPM vs pitch= speed, Maybe 8x10 pitch??
I flew an 8x10 too, and it was quick, but the delta still smokes it from what I can tell and I doubt it is close to 200, I'm guessing 170's but I hope to find out fer sure in NC. A while back someone did an article everal years back in RCM&E I think, about putting an MVVS RE engine in a Magnum and burying the pipe. As I recall the article ended with him having continuing trouble with the engine and the numbers didn't look too exciting. I originally bought two Magnum R's with that idea as well for number #2, but I lost interest after flying the first one. It's fast and all that, but I never fell in love with it's flight characteristics. #1 is in limbo, I dinged the LE, and if I was motivated could have it completely repaired in about 45 minutes I figure. But when I stripped the wing and saw how bowed and twisted it really was I put it away for now. I might pull it out later, refit and thrash it.
MJD
I have not built my Magnum yet. Was breaking in the engine on the Kaos, found a problem with the plating and sent it back. I now have the engine back, so it's time to start the Magnum build. Probably start with a 9 x 7 for maiden. Will likely break the engine in again on the Kaos.
Too many projects, not enough time...
great prop choice for all round flying with easy lauch, vertical infact..!
time flies by.....especially at the field
ORIGINAL: MJD
What puzzles me is why it was never spec'ed as RE in the first place.. a golden opportunity missed in my opinion, it's already a special purpose engine after all.
MJD
MJD
Is there a webra RE that could be tweaked?
I've looking at a rossi 50, great horpower without the tuned pipe yet on it
ORIGINAL: BiggerDanno
Made from a Webra crankcase. Would require a significant change to the mold. Which would likely drive the price way up. I'm thinking it was just an attempt to see how much a Webra 50 could be tweaked.
