Magnum with no throttle servo
Reply
Old 06-25-2003, 01:44 AM
Mattyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Magnum with no throttle servo
is anyone flying the magnum without throttle servo to save weight. just wondering as i noticed that on the 50v1 the throttle is held open by spring. and the idea is to go flat out anyway so who needs it ??????
Mattyb
Mattyb is offline
Old 06-25-2003, 03:53 AM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
specs on hitek HS-81:
Motor Type 3 Pole Ferrite
Bearing Type None
Torque 4.8/6.0v 36 / 42 oz. 2.6 / 3.0 kg.
Speed 4.8/6.0v 0.11 / 0.09 second
Size 1.2 x 0.5 x 1.2" 30 x 12 x 30 mm
Weight Nylon 0.58 oz. 16.6 g.
have you ever handlaunched one of these ???
have you considered the possibility that you may have flutter, lose a control surface in flight, servo failure, midair collision.????
would you now like to throttle back instead of going in full bore?
at 3.5 lbs the micro servo will increase your weight by about 1%
the pylon racers running venturi instead of a carb sill have a way of killing the engine...part of the rules.
if you want to make your magnum faster clean up the airframe...
all the blunt trailing edges on the tail are drag city
Crazy4Flight is offline
Old 06-25-2003, 04:12 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i run a GRRT, no throttle, i now have a cut, but i didnt before, talk about praying nothing goes wrong.......
Cactus. is offline
Old 06-25-2003, 11:20 PM
Mattyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i see your point. after starting it the other night i would not like to have no throttle. barely hang onto it
Mattyb is offline
Old 06-25-2003, 11:22 PM
jwoolridge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do engines with a venturi kill the throttle in an emergency.
James
jwoolridge is offline
Old 06-26-2003, 12:18 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used to use a fuel line pinch in the past...
Nelson engines have a venturi, but it looks like a carb... you can close the barrel to stop the engine...
Rudeboy is offline
Old 06-26-2003, 07:29 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you start a turn rich, it runs like a bag of $*** till you get to the patch, lean it out and throw. i now have a little hook round some tube and it pulls it tight against the fire wall to cut, i've not tried it yet, waiting for a pipe, but i may even be able to sort out a rich setting in air by pinching it slightly
Cactus. is offline
