Tuned piped OS 75AX
Reply
Old 07-28-2009, 12:32 PM
JS615
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tuned piped OS 75AX
Would there be alot more power out of a 2 Stroke OS 75AX with a Tuned pipe setup??????? i am thinking of trying it on a Kyosho Kelly F1, This engine runs very well with the stock muffler, but if i could really get alot more power with a piped setup i would spend the money. I just hate to spend the cash on something thats not going to add much power.
Any ideas??????????
JS615 is offline
Old 07-28-2009, 09:00 PM
PAINLESS
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tuned piped OS 75AX
You could see a 1500 rpm or so increase with a tuned pipe. The key word here is "tuned". The length needs to be tuned to you particular set up including the prop and nitro content of your fuel and head clearance. A change in any one of these would require a change in tuned pipe length. Most tuned pipes come a little long for trimming purposes, at the input end. Your engine will use more fuel turning a higher rpm too. Most sport engines come with mild port timing and way too much head clearance for longevity reasons. You can increase exhaust duration when using a tuned pipe and see significant gains in rpm.
PAINLESS is offline
