MVVS 3065 .40 GRRT Pylon Engine in a Delta: Any info on this combo?
Would this be a good engine for a delta?
Easy to adjust, reliable?
What sort of speed is to be expected?
GA
If you are putting it on the Diamond Dust it is a good combo. I am running the it is a good combo. With the very light wing loading it has no problems launching.
I am not sure about the 3065 GRRT. I am running the 3070N .40 GRRT FAI PYLON rear exhaust, rear intake version and it works great.
Keep in mind you will need to order a carb also unless you want to use the WOT venturi. And for that engine you need the small header to go from rectangle to round for pipe.
One of the reasons I went with the 3070n is because it has a round exhaust on it already. Pipe clips directly on engine.
