Phoenix Models F-20 tail linkages?
Reply
Old 09-08-2009, 10:35 AM
Quikturn
My Feedback: (12)
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Phoenix Models F-20 tail linkages?
Can anyone post a picture of their Phoenix F-20 tail linkages? I have a photocopied instruction manual with the F-20 I'm building and the pictures are very poor quality. It's hard to see how this goes together.
From what I can tell, this is not the best design. I've read some people lost their airplane because of control horns breaking. Now I see why.
Quikturn is offline
Old 09-08-2009, 01:09 PM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Phoenix Models F-20 tail linkages?
Sure will, I just finished mine over the weekend. When i get home tonight i will take some pic and post.
darthvaj is offline
Old 09-08-2009, 01:18 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bet you can find some pics in this slideshow from the huge thread on the Phoenix F-20:
http://www.rcuniverse.com/forum/gall...readID=3410514
Kmot is offline
Old 09-08-2009, 03:07 PM
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mines a stock US model, over 100 flights no issues
Dieselman1220 is offline
Old 09-08-2009, 05:20 PM
Quikturn
My Feedback: (12)
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the link Kmot. Looks like there are different versions of this airplane. I beleive I have the US version which has both rudder and elevator servo mounted internally. It looks like the pushrods need to be bent which can cause them to flex under a load. There is a picture of Rever's F-20 that crashed due to a broken elevator control horn. Any lessons to be learned here? I purchased a control post just in case.
Quikturn is offline
Old 09-09-2009, 04:37 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Quikturn
Here are the pictures i promised of the tail linkages i used on mine.
darthvaj is offline
Old 09-09-2009, 04:40 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Quikturn
Sorry i can only load one pic at a time, here is the rudder and fin assy.
darthvaj is offline
Old 09-09-2009, 09:14 AM
Quikturn
My Feedback: (12)
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the pictures Darthvaj.
Is it posibble you can send a picture of the elevator/rudder servos? Looks like you used a clevis with a ball joint to cope with the pushrod/control horn angle. Good idea!
I'm thinking of using a pushrod from the rudder servo and run it up to the steering linkage as well. That way I can avoid a steering servo.
FYI, I was using a z bend tool for the aileron linkages and the supplied pushrods broke! I didn't realize it until I was installing the second linkage. So if anyone out there has the supplied pushrods installed, I would replace them. They could break in flight.
Quikturn is offline
Old 09-09-2009, 09:44 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Quikturn
No problem, I will take some more tonight after work and post them by morning. As for the nose wheel stearing i used a secound servo located up front and linked the rudder and steering together.
darthvaj is offline
Old 09-09-2009, 09:00 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some pics of mine:
ID:	1271945   Click image for larger version
ID:	1271946   Click image for larger version
ID:	1271947   Click image for larger version
Kmot is offline
Old 09-09-2009, 10:49 PM
Quikturn
My Feedback: (12)
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the pictures Kmot. Looks like you used heavy duty clevises too.
I like the pipes you have on your engine, very cool!
Quikturn is offline
Old 09-10-2009, 04:28 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Quikturn
Quikturn, here are the pics for the rudder and elevator servo setup you asked for.
Sorry Quikturn, i seem to be haveing trouble uploading pics today, it says "server unable to display page" everytime i try to load a pic. I will try later today/tonight.
darthvaj is offline
Old 09-10-2009, 09:10 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: darthvaj
ORIGINAL: Quikturn
Sorry Quikturn, i seem to be haveing trouble uploading pics today, it says ''server unable to display page'' everytime i try to load a pic. I will try later today/tonight.
OK lets try this again! Here are the pictures you asked for of the rudder and elevator servo setup. I used 4-40 rod and links on all connection including alierons.
darthvaj is offline
Old 09-10-2009, 09:12 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
picture #2 of the nose wheele steering servo
darthvaj is offline
Old 09-10-2009, 09:48 AM
Quikturn
My Feedback: (12)
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the pictures Darthvaj! I had trouble uploading images too but I it's because my files were too big.
Looks like you set up the tail linkages a little different than Kmot did. Are there any bends in those linkages? I like you use of ball joint clevises. The control surfaces are not in line with the servo arms and make for a tricky setup. That may explain why some of these airplanes crashed.
As for the steering linkage, I plan on routing a pushrod from the rudder servo. I'll post pictures if this works out.
Quikturn is offline
Old 09-10-2009, 10:27 AM
darthvaj
darthvaj's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Quikturn
Quikturn, All push rods are streight from the servo to the control horn. I did have to notch out one bulkhead just aft of the servos to get the right angle. I thought about running a steering cable from the rudder to the nose wheel but i like the direct drive from a servo, i can adjust the endpoint and travel.
darthvaj is offline
Old 09-14-2009, 12:41 AM
Quikturn
My Feedback: (12)
Quikturn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kmot,
From what I can tell, the way you set up the elevator/rudder linkages is the way it's supposed to be. When I lay out the pushrods this way it requires no internal modifications (cutting of balsa). The rudder pushrod does need to be bent a little however.
Quikturn is offline
Old 09-14-2009, 10:32 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup...
Kmot is offline
