Nelson Q40 without a home.
Hey everyone. I have a strong running Nelson Q40 motor without a place to call home. I want something that is as fast as humanly possible, while staying reasonable in cost. Spending 600 bucks for a Q40 airframe is out of the question, as I would rather spend that kind of money on a warbird or 3D machine. Any suggestions? I have a clipped wing Lanier Predator with a Q500 Nelson on it, and frankly, have flown it so many times that it is no longer "fast." Thanks!
RE: Nelson Q40 without a home.
ORIGINAL: RocketRob
can't for the life of me understand willingness to spend money on a 3d plane but not on a 200mph plane where quality should matter, if only for your own safety
We'll soon find out if 32" deltas make a good home for them, stay tuned to CP's progress on his contraption.
MJD
ORIGINAL: MJD
We'll soon find out if 32'' deltas make a good home for them, stay tuned to CP's progress on his contraption.
MJD
MJD
That's not an FAI engine though. Aren't they quite a bit snottier? CP's is some fearsome piped RE 29k+ thing running on .15 props and capable of pulling his arms out if he forgets to let go in terror.
MJD
MJD
We don't know exacty what the OP has.
cp, do you know the differece of your Q40 rear exhaust engine and Dennny's Q40 side exhaust (besides exhaust)?
Mike, the Q40 turns a 7.4x8 in the mid 20s in the air. The FAI turns a 7x7.5 about 30,000. The Q40 has normal liner and crank timing, just big ports. The FAI engine has pretty radical timing and large ports. A typical FAI set up uses over 190 degrees of exhaust. The FAI engine has to be finger choked while it's running to get near staged rpm or it will just sit there and idle, spitting fuel out the venturi. The Q40 is much more flip and go.
ORIGINAL: RocketRob
Your assumption that when I say that I don't want to spend 600 dollars on a fast airframe does not mean I want to sacrifice quality or endanger me or anyone else. Please do not insult my intelligence insinuating that I want something "cheap" that just goes fast. I can't for the life of me understand the willingness to insult me just because I wanted some opinions on airframes. The reason why I would rather spend that much money on a 3D plane is because I can fly those all day, where as a quickie might go up just once or twice.
ORIGINAL: combatpigg
If you really want a rush, hook that engine up to a C/L plane on 60 foot lines.
I hate to think of that scenario with a human who just can't turn fast enough with a 3hp ukie.. gee that wouldn't be funny at all.. not one bit..
MJD
Mike, the Q40 turns a 7.4x8 in the mid 20s in the air. The FAI turns a 7x7.5 about 30,000...
