Suggestions for an engine I have
Reply
Old 09-11-2009, 11:03 PM
fabmaster911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Suggestions for an engine I have
I have a YS 61 AR R Long Stroke. The engine is a rear exhaust and pumped. I have the header and tuned pipe for it already. I want to mount the engine upright and run the pipe over top. This eliminates a bunch of airframes. I want to make something Freaking Fast. Any suggestions will be appreciated. Thanks
fabmaster911 is offline
Old 09-11-2009, 11:09 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Suggestions for an engine I have
I flew with a guy who had the same set up on a oversized Quickie type plane.....what a dog. The engine really screamed, but the plane was just too big and heavy.
Why don't you try it on a delta?
combatpigg is offline
Old 09-12-2009, 05:51 AM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that is an excellent engine, a lower rpm torquey pattern engine. one of the better engines for the classic pattern era planes. the YS .60 short stroke though will give you brute power and much higher rpms. however the .61 LS would be perfect in a Bridi Escape (retracts of course) or similar 80's ballistic pattern plane. there is a vast data base on that era's plane that can be found in the classic pattern forum.
dhal22 is offline
Old 09-12-2009, 07:15 AM
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My pal stuck an OS rear port into a WM Dago Red. Pipe went though the fuse and it was fast too.
tIANci is offline
Old 09-12-2009, 08:09 AM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it depends on which os rear exhaust. the v, vf or vr are high revving engines. the rf's (and hanno's) are more of a pattern engine.
dhal22 is offline
Old 09-12-2009, 08:34 AM
fabmaster911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking like some great info, keep it coming and thanks
Old 09-14-2009, 12:28 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your best bet it to put it where it really belongs - pattern ship. Most of the designs from the 1970s and 1980s were designed for speed (energy) and many will hit 100+mph easily when set up properly.
Even though it is the LS version, that does not mean much. The engine can and will unload on a slightly lighter prop, but there is no need to push it that far. Prop and pipe it to turn about 12,500 rpm with an 11x10 out front and it will get you all the speed you need.
Look for some of the older but larger RE pattern designs - Aurora, PA-2, T2A Mk II , Deception, EU1-A, Brushfire, UFO, XLT, Escape, Magic, Illusion, Atlanta, Citation, Bootlegger. Even a Compensator or Dirty Birdy will work, you will just have to build your own pipe-tunnel canopy. Quite a number of pilots use to fly Tipoare, Tipo 750 and Curare designs with RE engines - pipe along the side of the fuselage (or moded with the pipe slightly tucked in)
Suggestion: look in the Classic Pattern forum. Information on where to get many of these aircraft. Several are in re-production and available once again
With the right setup, the gear up, and the pipe/engine/prop matched - you will have yourself an extreme speed pattern ship.
bob27s is offline
Old 09-14-2009, 08:51 PM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
there is more classic pattern info available there than you can consume in many many months. the guys there will options for all types of variables, but bob is right, that is a good list he gave you.
dhal22 is offline
Old 09-14-2009, 09:31 PM
fabmaster911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the help guys I am going to start researching planes right now. I've never flown a pattern plane, might be fun.
Old 09-14-2009, 09:38 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: fabmaster911
You don't know what your missing, they make anybody look like they are an expert.
jeffk464 is offline
Old 09-14-2009, 09:44 PM
fabmaster911
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm definetely going to get one then.
