1930's racers
Reply
Old 09-19-2009, 01:33 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1930's racers
I love the looks of 1930's era racers and thought I would try to design one loosely based around Q500 dimensions with a Q500 wing. My goal was for sport/fun scale, simple construction, with fast sport performance on a 40 sized sport engine. Its going to look kind of stretched out because I'm trying to keep frontal area down, I pretty much set the height and width based on the dimensions of a 55AX engine. Anyways interested in input/critiques.
ID:	1278206   Click image for larger version
ID:	1278207   Click image for larger version
ID:	1278208   Click image for larger version
jeffk464 is offline
Old 09-19-2009, 03:50 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 1930's racers
I noticed that tower hobbies has a control line plane with about the exact dimensions(2 1/4" x 4") I'm looking for. Maybe I should build the front to fit this cowling perfectly, its probably a more stream lined front end than I can do on my own. Actually that whole plane is kind of very similar to what I want the model to be like, only with a Q500 wing and 1930's racer profile.
ID:	1278296   Click image for larger version
jeffk464 is offline
Old 09-19-2009, 09:30 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is one I built from MA plans that uses a .25. It runs in the low 100s with a .25FX. It's a pretty cool little plane. This picture is quite old but the plane is still fine.[8D]
vicman is offline
Old 09-19-2009, 10:10 PM
lfinney
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats a slick looking plane vicman, one our club members has a 60 size version with a 91 OS engine on floats its 125mpph range plane, flies like its on rails
lfinney is offline
Old 09-19-2009, 10:42 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
His is a kit, mine is built from plans if I'm thinking of the same one. I've seen a few of those 60 size models around. Mine flies just like you said. It's not all that aerobatic but it really grooves around the poles and turns heads for a little .25. The build article is from 1982 I think, and was designed to run with the new (at the time) Q40 class. I had to add some carbon fiber rod struts to the horizontal as well as strengthen the elevator after it snapped during a fun race. Luckily I was able to get it back on the ground with only half the horizontal and elevator since one side ripped itself off in a turn. [X(]
I got my best speed with an MVVS .28 as testing and going for all out speed progressed. It was a pretty easy build overall. In fact I think I still have a fuse side frame laying around where I stupidly built two of the same side over the plan. Man was I mad at myself for wasting all that spruce! [:@]
vicman is offline
Old 09-20-2009, 09:47 AM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jeffk, What size engine will that cowl hide?
Thanks Rob
RocketRob is offline
Old 09-20-2009, 09:51 AM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Keith Ryder Racer - Jack Rabbit
Old 09-20-2009, 10:01 AM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
French Caudron
ID:	1278697   Click image for larger version
Old 09-20-2009, 12:53 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gee, I feel like such a hack now. Great looking planes Rob.
Are those your own plans or from somewhere?
vicman is offline
Old 09-20-2009, 05:48 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, perfect. Those planes are exactly what I was going for. The cowling fits up to a .46 size engine.
jeffk464 is offline
Old 09-21-2009, 10:34 AM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That French Cauldron is gorgeous. The wing is tapered which really isn't what I'm going for, but wouldn't that be the perfect airframe to base a Q40 off of. It seems like the design allows you to cowl up the cylinder head and improve stream lining. Am I missing something here. By the way, that plane gives me a nice new wallpaper for my laptop.
jeffk464 is offline
Old 09-21-2009, 11:59 AM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry about the photos, I always wondered how people got the big photos inserted and now I do it by accident?
Any way the Jack Rabbit (brother of Eight Ball and Firecracker) is a ARF by HET in Holland. I have an inverted MPJet .061 diesel inside.
[link=http://www.rcuniverse.com/forum/m_7283054/mpage_1/key_/tm.htm]Jack Rabbit[/link]
The Caudron is a glass fuse/ foam wing by JM Glasscraft with the same little 1cc Czech Diesel I affectionatly refer to as my fastest diesel - spinning a 4.75x6.25 prop.
I have plans to do another Caudron with a piped Picco .8cc glow
[link=http://www.rcuniverse.com/forum/m_8014926/mpage_1/key_/tm.htm]Caudron C-460 Rafale[/link]
A video link near the end of the thread
I want to do a Fokerts Racer a bit larger for a hot 2.5cc - .15" Team Race Diesel Engine.
I have a set of plans but might need to upsize it a bit and increase the wingspan/area.
Old 09-21-2009, 05:30 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I feel much better now knowing my plan built is being compared to an arf
vicman is offline
Old 09-21-2009, 06:26 PM
lfinney
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this would be a great one design racer, wish someone had a mold for the fuse in 40-60 size[8D]
lfinney is offline
Old 09-23-2009, 06:57 AM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the Fokkerts SK-3 Jupiter
short stubby wings to an extreme[8D]
Old 09-23-2009, 05:12 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like a clipped wing Beech [8D]
vicman is offline
Old 09-23-2009, 11:50 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"this would be a great one design racer, wish someone had a mold for the fuse in 40-60 size"
Yup, so many cool planes out there and all we see is the same old planes at the field everytime, mustangs and extras.
jeffk464 is offline
Old 09-24-2009, 07:11 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RocketRob
I want to do a Fokerts Racer a bit larger for a hot 2.5cc - .15'' Team Race Diesel Engine.
[8D]
Hey Rob - I have a KMD team race diesel that runs like a bear on an 8-6 prop, meaning it should do the same on smaller and pitchier too. I've been thinking about a home for it for a while, and of course it has to be something "different", otherwise I'll use an FP..
It has an intake bore of about what, 0.005" or so, no wait, about 1/8", and I know diesels don't need the throat size but I bet there is a lttle less economy and a bit more power to be had. It's skinny too, so the fuselage can border on anorexic and still fit.
Mike aka MJD
MJD is offline
Old 09-24-2009, 07:12 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jeffk464
What engine is in that I wonder? Gypsy Major? Has the right number of stacks. [EDIT - no dummy, it went 505 kph.. it's a Renault Bengali]
Beautiful airplane!
MJD
MJD is offline
Old 09-24-2009, 07:18 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RocketRob
Do you have Corel photo paint or the like? I use Photopaint, and the "resample" function allows you to set the dimensions. I use my son's camera all the time, and before I knew the little I do know about picture sizing, I figgered you just post them. Turns out he has his camera set for about 2'x3' shots, and I didn't know when you post them they come out big too - the reaction to my first RCU picture posting was kinda funny, mostly "post #%$#$&^ smaller pictures dumbass!". If-n-when I remember to set the camera to "VGA" I can upload and post pictures directly.
So... folks like these things eh? Always looking for kit design ideas.
MJD
MJD is offline
Old 09-24-2009, 07:24 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lots of ideas here:
[link=http://www.airracinghistory.freeola.com/index.htm]Record breakers[/link]
MJD
MJD is offline
Old 09-24-2009, 06:13 PM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MJD, Lots of stuff to respond to here, but then I know I owe you another as well
The Team Race Diesel - they use smaller ventruis to minimize the fuel burn. I had a few of the Fora junior/pioneers which had a 3.4mm venturi spinning a 7x6 around mid 15's after I drilled one out with a #1 drill bit it would do 16,900 on the same prop.
On the photos, I have always left my camera on max resolution and they would load up small and normal, so I think something was off on the RCU software when I loaded these two.
Old 09-24-2009, 08:58 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No worries Rob, just my morning three mugs of tea trying to wake up babbling..
I've had many fleeting thoughts about these '30's-ish era aircraft and how they would transition into neat models, whether somewhat scale or just as inspiration for a design.
MJD
MJD is offline
