OS 46 AX
RE: OS 46 AX
ORIGINAL: combatpigg
Why worry if it looks stock or not?
ORIGINAL: fomocokid
Are there any speed secrets for a 46 Ax that I could use and keep it stock looking?
RE: OS 46 AX
Anyone with any self respect would never cheat at racing, just ask Richard Petty.
Hey CP, I know who Richard Petty is but is there a story behind that? I don't follow racing but dig it when I do watch.
MJD
RE: OS 46 AX
They would ''rip him a new one'' if he asked the same question at the pylon forum......[:-]
My old boss used to race this and that and told us about all kinds of stuff that went on, including cheats just like on video games - tap the brake or push some other button to the rhythm of La Bamba or some such thing, and the ECU would switch fuel maps while in the starting grid. And back again later.
MJD
RE: OS 46 AX
MJD, when I was a kid, ABC Wide World of Sports reported that a race he won had not really been won until a few cars got torn down and looked at. The way I remember the story, his big engine needed a restrictor plate between the carb and the manifold. At the inspection they do prior to qualifying or racing, the plate would look OK.......15/16" holes [or something like that].
The inner 1/8" of the holes was built up with a low temp material that melted away and gave a performance boost. Any way, there have been a lot of cheaters. Sometimes it is hard for the judges to pick a winner. About 10-15 years ago a team was disqualified and heavily fined for using after market studs instead of genuine factory studs to hold down a carburetor.
They have a ton of rules, so you almost need a lawyer to compete there, I'll bet.
MN
RE: OS 46 AX
They tear down at the nats also.
Finish in the top five and your plane will be impounded as you come in from your last heat. You tear the motor down in front of inspectors (including Dub Jett) as every piece is measured, checked, and given the once over for modifications.
You are not awarded a finish place until after a successfull tear down. Even if you know your motor is box stock, the temperature seems to rise about 10degrees under the tent as your pulling it apart.
RE: OS 46 AX
The old rulebook I'm looking through says [for Q40] that the engines shall be unmodified.......but they say elsewhere that the venturis can be modified and that other manufacturer's parts can be substituted. Reading it this way, a long stroke kit could be substituted.
MN
RE: OS 46 AX
The venturi can be modified in Q40, but not to exceed a no-go gauge of 9mm, in Q500 you are not allowed to modify.
Molded plastic has a little tolerance, and I guess they allow you to get right up to the limit while allowing the manufacturer a chance to make them plastic without fear of being to big.
Theres a few things that can be substituted (like bearings and shims), but without a new case, you couldn't fit a LS piston / sleeve into a SS case. Henry has been converting these at a cost by removing some material under the crank and some sort of ring up top to extend the case for the longer stroke.
Still some gray areas in there, but for the most part, pretty solid.
My Feedback: (103)
CA
RE: OS 46 AX
