RFB 600 Fantrainer
Reply
Old 11-28-2009, 12:37 AM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RFB 600 Fantrainer
Hi all,
Currently, I'm scratch building a RFB Fantrainer using a "Xerox-ed" plan from a 2001 magazine. The wing span is about 70 inches and designed for 60 size engine. However, I have planned to fly it with OS 55 AX with 10 x 7 blades prop. I know that it would not be a speed demon, but will a OS 75AX or Rossi 65 with 10 x 7 " 3-blades prop makes a difference ?
ID:	1321899   Click image for larger version
ID:	1321900   Click image for larger version
ID:	1321901   Click image for larger version
fullmoon_sg is offline
Old 11-28-2009, 12:50 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RFB 600 Fantrainer
The CG is the biggest issue with rear mounted engines. You want an engine that weighs the same as the original, or even less if the original plane needed lead in the nose. Next priority is RPM potential. The "fan" is a cut down prop, so the engine must be able to rev it good to make enough thrust. I'll bet a Jett .60 would do the job... Actually, any engine that compares favorably to the original would be OK. Once you fly the plane successfully with the recommended prop, then you could try more pitch, or a 3rd blade.
These planes have a unique sound and look very cool flying.
combatpigg is offline
Old 11-28-2009, 06:28 AM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cool, i'd like to see this one happen.
dhal22 is offline
Old 11-29-2009, 05:57 PM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Combat, the original set-up is ASP 75 with 10 x 7 prop. In fact, the duct fan only allowed max 10" prop. Therefore, I think the current technology, which is OS 55 AX, is comparable to ASP 75 in 2001. Nevertheless, I will upgrade the engine to OS 75 AX if needed. As for the engine weight at the rear, it is about 15 cm behin C.G. Not so bad I think.
Hi David, I will make it happen. Will post video when I have done it. Cheers.
Old 12-04-2009, 11:41 PM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some update to my building. However, I really need some opinion here. I just did a rough calculation and estimated that the flying weight is about 6 t o7 lbs or between 3 to 3.5 kg. Will my OS 55 AX with 10 x 7 " 3 blades pusher prop is able to fly this plane? I'm not looking at high speed but at least not flying at full throttle just to maintain flyable air speed. Many thanks.
ID:	1327027   Click image for larger version
ID:	1327028   Click image for larger version
Old 12-04-2009, 11:56 PM
lfinney
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
with that much wing area yes it will, but a 60 or 75 would be nice, a 10x8 three blade would be better, the 55 is a torquer, keep on building!
lfinney is offline
Old 12-05-2009, 12:21 AM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Ifinney. Right now is to keep the flying weight low. To make flying less stress, I will include a split-flap. Neverthless, if need to, I guess I have to buy a OS 75 AX to fly this machine. Cheers.
Old 12-11-2009, 11:09 PM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Update to my building..
ID:	1332324   Click image for larger version
ID:	1332325   Click image for larger version
Old 12-12-2009, 12:10 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your plane is looking real nice! It looks like most of the hard work is finished. How did you finished the fan duct? Is that Monokote or paint?
Old 12-13-2009, 07:56 PM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Combat, thanks for the comment.
The fan duct finishing is not good and I think it can be better. The fan duct is done with 1/16 ply and 2 x 1/16 balsa, and covered with Monokote. Actually, I'm worried of how to build this fan duct as I have no experience with it. However, I managed to find a plastic pipe about 10.5" diameter and used it as a my mould. Here the pictures :.
ID:	1333760   Click image for larger version
ID:	1333761   Click image for larger version
ID:	1333762   Click image for larger version
ID:	1333763   Click image for larger version
Old 12-13-2009, 08:28 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It looks like a pretty tough job to make something perfectly round out of wood. Your work looks good from here.
If the wood is soaked in full strength ammonia, it can make the wood real easy to mold. Faster acting than using hot water.
You know, 2 tubes could be used for a mold...[I'm just thinking as I type this].....a solid pipe for the inner mold and a split pipe for the outer mold. A friend built the smaller version of this plane for a Cox TD .049 engine and it was very fun to watch. It was a very smooth flyer that everyone wanted to get a good look at.
Old 12-14-2009, 10:38 PM
cncswiss1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the mold as shown is an external mold, you could inflate a balloon inside everything to "clamp" it
cncswiss1 is offline
Old 12-15-2009, 08:40 PM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Appreciate both of your tips. I think it will be a great help, probably my next project, building the RC veritgo (the vertical take-off plane). I got this plan from the ebay and it requires some works on the fan duct.
I just can't wait to finish this project and see this plane flying in the air. With the look and sounds of pusher engine, I think I will be enjoying this plane for many many months.
Old 12-15-2009, 08:54 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Real nice job on the flap setup.
iron eagel is offline
Old 01-03-2010, 02:48 AM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Iron Eagel.
Pre-maiden day. Hopeful to have my first 2010 flight by maidening this lovely plane of mine. Everthing is good to go except the canopy.
ID:	1348010   Click image for larger version
ID:	1348011   Click image for larger version
ID:	1348012   Click image for larger version
ID:	1348013   Click image for larger version
Old 01-03-2010, 02:53 AM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No matter how hard I've tried, there is no way I can start or flick the engine with the starter. There is no space for my start to engage the propeller soomthly. So, I came out with a easy way to start my engine. This rope can continue to provide two constant turn. Should be good enough to start the engine.
Old 01-03-2010, 03:01 AM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The D-day. Everthing is completed except half-canopy. The best way is to tape the other uncovered canopy....
ID:	1348019   Click image for larger version
ID:	1348020   Click image for larger version
ID:	1348021   Click image for larger version
ID:	1348022   Click image for larger version
Old 01-03-2010, 03:16 AM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is it !!![8D]
http://www.youtube.com/watch?v=c-SvDw0xKU8
Old 01-03-2010, 11:21 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's amazing!
Congratulations on a great job. That looks like a tough area to fly from but the plane tracks very well.
Old 01-03-2010, 11:48 AM
tIANci
tIANci's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fullmoon ... nice one! Wanna go EP or not? No need to flick start ... hehehehee ...
tIANci is offline
Old 01-03-2010, 12:06 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great job!
Old 01-03-2010, 06:18 PM
fullmoon_sg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Combat. I had modified the landing gear slightly to suit the runway condition. The nose gear was intentional lowered to have more grips and tracking during take-off. Also I have increased the incident of the wings by positive 2 to 3 degrees.
Hahah TianCi, no thanks. Electric is not my cup of tea and I think it is more expensive to operate. I was told the plane would need at least 10s lipo to run it. Anything I think I'm also addicated to nitro smell.
Thanks Iron Eagel.
Old 11-26-2016, 03:02 AM
Pecanpatch
Pecanpatch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Brother has the 69" wing span RFB 600 kit and it uses a O.S, .46 with a Tornado 10 x 6 three bladed prop cut down a little bit......... flies great!
Pecanpatch is offline
Old 12-31-2016, 09:30 AM
garard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might find this latest jet powered 1/4 scale model of interest. Looks really great. Cheers Gary
https://www.youtube.com/watch?v=NuL9aQksF0s
https://www.youtube.com/watch?v=uzCTrPp19sg
https://www.youtube.com/watch?v=EneATcOnW60
garard is offline
Old 01-04-2017, 07:49 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if going to buy the 75 AX might as well buy the 95 AX as it is the same weight if not a tad less. Jett also make a Pusher version of his mufflers that works well. APC make a 10x7 pusher that would be perfect for this application with the 55AX and the Jett pusher muffler.
airraptor is offline
