aileron servos for .40 Patriot (HELP)
ok first of all there are just too many choices.........it's like walking into Tire shop.
i am setting up the Patriot with a Jett 50 and will use a servo for each aileron.
i will be running 6v, 12Z radio with 6008 Rx
price is not the issue here as with what's invested, i am not one to cheap out on the hardware.
my choices,
9602 (metal gear)
http://www3.towerhobbies.com/cgi-bin...?&I=LXH307&P=0
9650 (nylon gear)
http://www3.towerhobbies.com/cgi-bin...?&I=LXDTB4&P=0
i like these because they can be side mounted.
other choices are,
9002 (nylon gear)
http://www3.towerhobbies.com/cgi-bin...?&I=LXVZN9&P=0
what i don't know is, are any of these up to the task?
my choices,
9602 (metal gear)
9650 (nylon gear)
other choices are,
9002 (nylon gear)
RE: aileron servos for .40 Patriot (HELP)
I beat the tar out of standard Futaba servos for years and years. Depending on how you set the linkage up, the aileron servos mainly need to put up with the jolt of landings and some engine buzz.
I would trust a pair of HS-225s if the plan is to use 2.
thx.....i could buy those as well.......problem is i already have the one i have listed. just not sure which/if they'll do the job.
ON, CANADA
I still use standard servos for alot of stuff, and 440 hardware, especially for a 40 size airplane. I also like the 225's, tough little guys.
225's will handle the elevons on a Screamin Demon with a .50 .. although I recognize there are certainly fancier servos available. But as a reference for torque output they are up to the aileron duty on the Patriot. I'd suggest you aim for a minimum of 40 oz-in, that number being pulled from my yoo-hoo completely but based on a dash of forethought. If you're going to spend that much money, would digital wing servos not be a thought? Like HS-5125's? At $50 a pop what makes the Futaba coreless minis more endearing in comparison? You may have your reasons, just wonderin'.
MJD
MJD
FL
Mike,
I was using 2xS3001 for the wings (one on each half). Keep in mind that the ailerons move very little on this model, it rolls really fast with just very little input.
Doug.
Doug.
MN
The 9650 nylon geared digital is a great servo. Has become the servo of choice in the fastest racing classes for those that prefer futaba.
Awesome servo.
Awesome servo.
I hadn't looked at the 9650 specs, I was lazily only referring back to the 9602's when I said why not use digitals instead of $50 coreless analogs. Indeed - the 9650 looks like a great little servo for this application as well as pylon model ailerons. And delta elevons.
Today's $15 standard "yawn" servos would have been high-end treasures not all that long ago.
MJD
MJD
OK, you guys and my friend Minnflyer made this a lot easier
since i already have the 9650's, i'll setup for those.
the 9602's are identical except they are analog metal geared but are for some reason a lesser torqu rating.........they'd work too except it seems the consensus here in the speed forum is to avoid metal gear...........or is that wrong?
the reason why i like Futaba and choose them first was built into me from when i grew up with my Dad....he was a stickler for staying with same brand items although, before he passed away he was known to use some RCD stuff..he likee the pricee
thx guys,
mike
thx guys,
mike
that makes sense Dave.
i remember my electric 3D planes that had HS-65HB's in them, and the ones that had the 65MG's.
the HB's stayed tight while the MG's develop a lot of slop. not going fast in those things so it didn't matter.
i read somewhere that it's a good idea to increase the width of the elevator on this plane......yes-no?
ORIGINAL: summerwind
But as to torque, beyond electronics the difference could just be gear ratio, as they are physically different gear sets. Or not, but Hitec for example usually has several sets of servos in "high torque" and "high speed" versions, meaning the output arm is in 2nd or 3rd gear. Or "sail winch" where the output arm is in 1st low but the feedpack pot is geared even lower yet. Well you get the drift.
MJD
