Sig Kobra(25size) w/32sx
Reply
Old 01-22-2010, 12:52 AM
evanspa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Kobra(25size) w/32sx
I am finishing up a Sig Kobra with a 32sx. Can someone tell me the best prop for this combo?
Also, any one who has built this kit, how did you set up the ailerons? Mine seem to have a bit of slop. should I go with dual Ail servos?
Thanks all
evanspa is offline
Old 01-22-2010, 02:04 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig Kobra(25size) w/32sx
I'd break it in with a 8x6...then fly with a 8x7 for awhile. I'm not sure what the ideal combo is with this plane, but the 8x8 might be the fastest prop you put on it. If the airframe drag is too much, you might have to settle for the 8x7.
combatpigg is offline
Old 01-22-2010, 12:55 PM
evanspa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks, motor is about 8 yrs old and runs like a raped ape.!
evanspa is offline
Old 01-23-2010, 11:43 AM
Textanker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ditto on the 8x7. Absolutely no comparison in speed for that motor. Several of my buddies and I have been experimenting with 32sx, 35AX, and TT.36, and we have been able to get 135mph in a dive. We are flying the GP Combat Series (P51, P40 and Mustang). If you want even more speed, and you will, buy a Jett muffler for that bad boy and watch it scream.
Textanker is offline
Old 01-23-2010, 12:04 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
8X7 should be about the best if you have the stock trike gear.
Mine was built as a taildragger and has a Jett .30 quick and agile.
Crazy4Flight is offline
Old 01-24-2010, 02:42 PM
evanspa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made a few changes, Retracts, tail dragger, Sheeted and glassed(minwax) wings/tail. Painted with auto paint. My AUW is 4 lbs 2 oz. About 3/4 lbs over the stock weight. I was thinking I needed a little more torque. I'll try an 8x7 and 9x6 for kicks.
evanspa is offline
Old 01-24-2010, 02:57 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bet you mean thrust, not torque. Don't drop the rpm of the motor with respect to the flight prop of choice, keep it singing so you have all the potential power available, but trade pitch for disc area (gear down) for earlier flights - this is what you are already plannng to do by swapping the 8-7 for a 9-6 or 9-5. Thrust comes from power applied to the appropriate prop choice. The drag is increased a little bit with the increased weight so the same prop choices should work, but you won't be able to yank it off the runway as quickly.
MJD
MJD is offline
Old 01-24-2010, 03:35 PM
evanspa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes Thrust is what I'm thinking. The nice thing about this 32 is it has as much power as a 40.
I'm trying the props listed because that's what I have. I am getting ready to build an AK models F-16 Prop-Jet and just wanted to try the Minwax Glassing technique. I mostly fly Slabs (MoAss60) So the speed thing is an experiement
evanspa is offline
Old 01-24-2010, 04:29 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, those are good choices. I only put down 9-5 because if I had all three on hand I'd check them all just to observe the differences and what they had to offer in terms of performance. I bet the 9-6 is perfect for test flights and decent sport performance; the 9-5 is probably thin on pitch to be of use in that aircraft.
I never did get my own OS .32 when they were on the shelf, but I've messed with them. Nice engine indeed. I want one for a Screamin Demon.
MJD
MJD is offline
Old 01-24-2010, 06:11 PM
evanspa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks I'll update my findings, once I get her airborn. I also have a 9x7 I'll try.
evanspa is offline
