Weston Magnum Question
Reply
Old 07-17-2003, 10:34 PM
strong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Weston Magnum Question
I put my westom magnum toghter the other day and have a question for some of the magnum pilots.Is 17000 rpm's with the west 50 engine and a 9/6 prop turning fast enough for first flit launch.....or must it turn faster.
strong is offline
Old 07-17-2003, 10:59 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never tried a 9x6 prop, so I can't tell you how fast the engine should turn it...
But 17000 on that prop is more than enough to fly the Magnum... it should pull right out of your hand...enough to go vertical out of sight...
Rudeboy is offline
Old 07-17-2003, 11:07 PM
strong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can you slow this plane down enough on first flit to at least trim it or must you fly wide open at all times.
strong is offline
Old 07-17-2003, 11:25 PM
cabanestrut2002
cabanestrut2002's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
magnums can be flown pretty slowly, but are built for speed, trim it at half throttle.
have you flown quick models before?
cabanestrut2002 is offline
Old 07-17-2003, 11:47 PM
strong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I fly a turbine trainer that dose about 100 mph and a pylon racer that must fly about 120 mph. But I have seen video of this plane and it is very fast.
strong is offline
Old 07-17-2003, 11:56 PM
cabanestrut2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
youll be fine then.
i was just making sure you werent a newbie trying to learn to fly on a magnum!!!!!!!!!!!!!!
Old 07-18-2003, 12:09 AM
strong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have lot of flying experience but no hand launch experience I want to get it right the first time. Also how will it bleed off airspeed and land.
strong is offline
Old 07-18-2003, 12:21 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 9x6 prop will provide you with plenty of thrust, but still, get someone to launch it for you the first time... at least until the plane is trimmed and you get used to how it handles.
The Magnum slows down pretty fast... compared to a sleek F3D race plane that is... It needs a fair amount of room, but not excessive.
Also, with that big prop it should slow down pretty fast when you pull the engine to idle... and it won't be that fast to start with so it will basically be like any sport plane.
The first thing I do when I fly a new plane is trim it... the second thing is testing the slow flight characteristics... I suggest you do the same thing while there is still enough fuel in the tank to go around once... but then again you know all that since you are flying a turbine trainer...
Rudeboy is offline
Old 07-18-2003, 01:22 AM
strong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank for the info.Yea I know to trim and start to test glide for landing but it's always good to hear this from someone who has been there and done that.
strong is offline
Old 07-22-2005, 01:02 PM
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Weston Magnum Question
I just picked up a used Weston UK Magnum ready to fly and have a few ??? What type or fuel nitro% should I use and what prop? Thanks
rcalbuquerque is offline
Old 07-22-2005, 01:24 PM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what engine is on your magnum
Evil Homer is offline
Old 07-22-2005, 01:29 PM
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it has the West 50V1 with pipe
Old 07-22-2005, 01:35 PM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I run Prosynth 10 through mine, happy as and it screams on a 8x8-10
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just checked Weston's web site...they say 5 to 15 % nitro and a 9/6 or 9/7 prop. The guy I got the plane from was running a 9/6 on 30% nitro. I think that's to much nitro but what do I know. I was thinking a 9/7 and 15%
Old 07-22-2005, 01:37 PM
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try the 8x8- 10..... thanks
Old 07-29-2005, 11:01 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
30% nitro is too much, unless the compression has been reduced via head shims. The Manufacturer's recommendation is 10-15% nitomethane Prosynth. If you don't have Prosynth use some other good quality synthetic oil fuel, but don't exceed 15% nitro with the engine as is out of the box.
I really don't see any point in the combination of 9-6 prop and 30% nitromethane. It's like trying to go fast in a sports car by adding a turbocharger then driving in 2nd or 3rd gear.. great for climbing hills but not for top speed! The usual recomendations are 9-6 for running in and test flights, then 8-8 to 8-10 for speed. The 8-8 may perform better if the header is cut down a bit, up to 1", leave stock for higher pitch.
Mike D.
MJD is offline
Old 07-29-2005, 11:28 AM
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mike thanks for the post....I got this plane from a wealthy club member who is a good friend. He said here fly this plane and after you crash it give me my motor and servo back. Of coarse the plane was battle damaged and needs a little detail work . The Magnum was set up with some very heavy servos (hitec 5645's) and was modified for rudder control. I removed these servo;s and went with hitec 5245mg's and returned the rudder to stock. My friend is not the type of guy who reads instructions or breaks in motors or installs head shims so I hope he didn't damage the motor. We fly at 5600 ft altitude here and I think he felt the 30% would help with the loss of power we get at this altitude. I will run 10% and a 8x8 prop. The plane is all fixed now and just needs some touch up in the covering. I will leave the pipe lenth as for now until I see how she fly's................Lou
Old 07-29-2005, 07:53 PM
strong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the engine is still good 15% fuel is plenty, magnum is a fast plane no matter what.I would try the 9x6 prop for easy first launch.Have'nt flew mine in months(chicken I guess)just remember not to use very much aileron movement at all.
strong is offline
Old 07-29-2005, 08:41 PM
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Strong....I finished her up this afternoon....was going to go to the field for a test flight but my friend ( launcher ) couldn't make it. I will try again tomorrow. As far as throws go I have no idea (no manual ) I may have to much aileron throw and will turn them down a bit. I mounted a 9x7 apc for first flight.
Old 07-30-2005, 01:48 AM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One thing to remember is this engine will work beyond the limits of the 8 and 9" APC standard prop range, so keep safe
Old 07-30-2005, 11:09 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Evil Homer
I don't think so... unless you use props with "zero" pitch... you'd have to use an 8x5 or 8x6 or something to overspeed it...
Rudeboy is offline
Old 07-31-2005, 01:53 AM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Rude, I will take your word for it, I only have one of the v50 and i generally am 9x6 on it, my comment was based on the theoretical maximum of around 17.5K and 20K for the 9" and 8" props respectivly as stated by APC, I do beleive the props unload to more than this once airborne, not sure about static RPM as i have never measured it (neighbours get anoyed before i get the chance)
Old 07-31-2005, 09:34 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rpm limits for APC sport prop are 190000/prop diameter in inches... this works out to 23750 and 21111 rpm for 8 and 9 inch props respectively.
Rudeboy is offline
Old 07-31-2005, 12:07 PM
Evil Homer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My mistake, i thought the figure was 160000/length of prop
Old 08-01-2005, 08:49 AM
rcalbuquerque
My Feedback: (172)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flew the Magnum for the first time Sunday afternoon....what a rush....after a poor launch and nearly crashing I got the plane trimmed out. I have no idea how fast or what rpm....fastest plane I ever flew....after many high speed passes motor guit and I crash landed off the runway...minor damage...can't wait to fly it again
