tailplane of magnum in line with wing?
Reply
Old 07-24-2003, 12:37 AM
Mattyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default tailplane of magnum in line with wing?
Just a thought, wouldnt it be more aerodynamical if you had the tailplane on the bottom of the fuse in line with the wing, Less drag?
Mattyb
Mattyb is offline
Old 07-24-2003, 05:39 AM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I doubt it would make much of a difference, and you couldn't have the anhedral in the stab if it was lowered or you'd bust the stab on every landing
actually, this is my assumption.
One of the reasons for the higher stab rather than directly inline, is likely because with it above the wing, it's in clean air, not the dirty air coming off the wing, this makes it not only more effective, but probably a reduction in drag as well.
The anhedral is typically a fix for coupling in a low wing bird, though with no rudder, I don't know what the fix would be. I would also think that the higher stab is less likely to be washed out by the wing in flare or nose high situations. But, this is just my guess
LGM Graphix is online now
Old 07-24-2003, 06:50 AM
Mattyb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that makes sense
Mattyb is offline
