If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 33 of 65 FirstFirst ... 23313233343543 ... LastLast
Results 801 to 825 of 1622
  1. #801
    Join Date
    Apr 2003
    Caracas, VENEZUELA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: H9 Jackal 50 Prop Jet
    Hi guys,
    My jackal is ready for maiden. I will post some pics and my set up. One question I have is control throws. I think per manual they are very high: 1 inch Up elevator?? I can't not even get there with that linkage. I think even low rates are still high.
    Could somebody post their throws (flaps, aileron, elevator..)
    By now I have like 20% less than the recommended in the manual, except for the Flaps in which I have pretty much the recommended.
    thanks,
  2. #802
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    FIREWALL24,
    A big welcome to the Jackal 50 funny farm, I mean club!! When I set my Jackal 50 up, I go with half the manual throws. The rudder I also max out on the throws. The only time I use rudder is on the ground. On my elevator here is my setup: Low Rate - 10MM up and down
    High Rate - 15MM up and down
    The ailerons are set the same way as the elevator. This setup my not work for you, but, start with half of the manual throws and work from there. Good luck with your maiden flight and please let us know how it went!!!
    Sonny
    aka
    jet22b
    Spitfire Brotherhood #12
    P-40 Brotherhood #52
    Great Planes Citabria DLE 35RA CC
  3. #803
    Join Date
    Apr 2003
    Caracas, VENEZUELA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jet22b
    FIREWALL24,
    Sonny
    aka
    jet22b
    thanks a lot Sonny,
    I will start from there. I really like to fly with low throws....
    What about flaps and down elevator mix? what is your setup there?
    I will try to maiden this Thursday
    Juan
  4. #804
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: FIREWALL24
    ORIGINAL: jet22b
    FIREWALL24,
    Sonny
    aka
    jet22b
    thanks a lot Sonny,
    Juan
    Juan;
    Because of the bad winter we have had in the States, my Jackal has only 3 short flight. Right now I have not setup the flaps/elevator mix. I can not recall if the nose drop shot up when I put the flaps out. Can not wait till the weather break, so I can rip into her. Juan, she is a keeper!! Also, my expo on aileron and elevator is set at 25% Good luck again and let us know how much you love her, and you will!! Have fun my friend!!
    Sonny
    aja
    jet22b
  5. #805
    Join Date
    Dec 2008
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Amir Assal
    ORIGINAL: jet22b
    What Prop Goes with O.S 55 and this jackal for Maximum speed?
    On my small Great Planes Revolver with the O.S. 55AX, I am running a APC 10x7 prop at 12,900 rpm with no Jett Muffler!!
    Now on my Jackal 55 with the Evo 60NX, I have a 10x7 APC, rpm between 16 to 17,100.
    Sonny
    aka
    jet22b
    what you Think about APC 10x8 prop on the O.S. 55AX with Jett Muffler.
    I'm currently running the 55 with Jett muffler and 10x9 prop. Turns about 14k on the ground. I found the engine did not like this much prop with the stock muffler, but with the Jett pipe it's happy.
    Makes my Kaos run about 110-120 mph.
    I had to add a 3/8" thick spacer to the pipe to clear the fuse.
    My buddy flies his Kaos with a Rossi 53 and pipe, our speeds are pretty much identical. Everyone loves to watch the "Dualing Kaos'"
  6. #806
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: BiggerDanno
    ORIGINAL: jet22b
    Sonny
    aka
    jet22b
    I had to add a 3/8'' thick spacer to the pipe to clear the fuse.
    My buddy flies his Kaos with a Rossi 53 and pipe, our speeds are pretty much identical. Everyone loves to watch the ''Dualing Kaos'''
    My I ask what Jett muffler do you buy for the OS 55AX??
    Thanks for the info!!
    Sonny
    aka
    jet22b
  7. #807
    Join Date
    Dec 2008
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pipe page
    See the JS-40-TT
  8. #808
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pipe page
    See the JS-40-TT
    Thanks for the info!!!
    Sonny
  9. #809
    Join Date
    Jul 2007
    WhitecourtAlberta, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got email from Dub my SJ56 has been shipped, it should arrive just in time, the snow is melting fast here and it will be time to break out the fast planes.
  10. #810
    Join Date
    Jul 2004
    West Warwick, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So I'm finally getting to assemble my Jackal. I'm at the part where it's recommending that I put the switch in the fuse. As nice as this would look, I'm thinking it may be a bit tight in there with all the plumbing for the retracts. Where do you guys end up mounting yours? How about a fuel dot location?
    Thanks!
    Pull up....Pull up...Wait I\'m upside down!!!!!
  11. #811
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: viper1676
    Thanks!
    viper1678,
    It is tight if you put the switch inside the fuse, but it do work!!! As for the fuel dot, I did not go with it. I can get to the crab line to fuel the tank. For me, I just love to put my switch inside to protect it.
    Sonny
    aka
    jet22b
  12. #812
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    viper1676,
    Here are 2 pictures of how tight the switch is!!
    Sonny
    aka
    jet22b
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1581188   Click image for larger version.
  13. #813
    Join Date
    Jul 2004
    West Warwick, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Awesome. Thanks for the photo's Sonny.
    Dave
  14. #814
    Join Date
    Feb 2005
    East Granby, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Evolution muffler fitts the O.S. .55 as well.
  15. #815
    Join Date
    Jun 2006
    Miramar, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: viper1676
    Thanks!
    Viper,
    Here's where I located my switch.
    Hope it helps,
    Doug.
  16. #816
    bob27s's Avatar
    Join Date
    Apr 2002
    Cleveland, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yeah that location seems more reasonable..
    Bob Brassell
    Dub Jett Engines and Products Support Forum Host
    rjbrassell@gmail.com or bob27s@hotmail.com
    RB-78
  17. #817
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys;
    Today I had 3 good run on the speed gun with the Jackal 50. The wind was out of the east at 3 to 5 knots, fuel 15% nitro, prop 11x6 APC. Each run was at 50 feet and level.
    First run 127 mph
    Second run - 135 mph
    Last run - 140 mph
    Air temp 51 degs
    As you can see, I do think this bird will go 150 MPH or higher!!
    Anyone else has some numbers?? Please post!! Also, if you just like to fly around and not speed, the plane do fly good on half throttle!! This is a keeper guys, and for the people that are still on the fence about this plane, buy this bird, you will be glad you did!!!
    Sonny
    aka
    jet22b
  18. #818
    Join Date
    Nov 2010
    miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello jet22b
    How you can go fast in the jackal 50?
    I have one with the description below:
    Weight: arround 9.00lb with empty tank
    o.s. 65ax with tuned pipe
    usingAPC11x7have 12,750 RPM
    usingzinger 11x8 have 11,850RPM
    With zinger propit's run around 132mph.
    Whath rpm do you recomendto mefor my o.s. 65ax andwith wich propsize?
  19. #819
    Join Date
    Sep 2010
    somerset, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    how well did the 65 ax fit?
  20. #820
    Join Date
    Apr 2004
    Millburn, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any suggestions on an engine for the Jackal for use in a noise-restricted field? How about using the Evo .60NX with the stock muffler and an 11x7 prop? How about the .52NX with the 11x7 prop? I know the Evo .52 with an 11x7 passes our dB test and pulls my Sundowner around pretty nicely, but it seems to be on the low end of the recommended engine range for the Jackal. I'm ok with losing some speed/power in order to be able to fly at all by keeping within our noise restrictions.
  21. #821
    Join Date
    Feb 2008
    Little Egg Harbor, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The pesky mounting blocks for the ailerons and flaps broke. Glue them with expoxy waited till it dried drill the 1/16 holes put thin ca. The next day I was screwing the servos when on block just cracked in half as did 3 more. Not sure how to fix this? Did anyopne else have this problem?
  22. #822
    jet22b's Avatar
    Join Date
    Aug 2006
    Olympia, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bmschulman
    bmschulman.
    The stock muffler do not make the Evo .60NX come alive like the Jett pipe do, but, it may fit into your noise restrictions. If you have the Evo .60NX, out on the test stand and see if it fit the noise that is set for your field. I can tell you the Evo .60NX on the JETT pipe is loud. I have yet to put it on the meter, because our club field is 10 miles from a stock car dirt track and when they are racing, they overlap our noise, so everybody is happy.
    Let me know the outcome of your noise test with the stock muffler on the Evo .60NX!!
    Sonny
    aka
    jet22b
  23. #823
    Join Date
    Jul 2004
    West Warwick, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So did anyone else find that when they tightened down the rear stabilizer, the 3 screws really don't tighten down? I lock tited them, but the bolts never really got snug. It seems like it is on there tight, I tried pulling on it, and it stays. Just making me a bit nervous.
    Dave
  24. #824
    _Tommy D's Avatar
    Join Date
    Feb 2004
    East Islip, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dave, did you use a washer to keep the wood from compressing?
    http://tommydsblog.blogspot.com/
  25. #825
    Join Date
    Jul 2004
    West Warwick, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I followed the instructions from the manual....lock washer and flat.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
