RCU Forums
-   Extreme Speed Prop Planes (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/)
-   -   Need Rossi .90 small heads (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/10874712-need-rossi-90-small-heads.html)
Jim Oliver 12-24-2011 12:16 PM
I need one or two small heads for the Rossi .90 DF engine; I have new large heads to trade or will purchase.
Jim
Pylonracr 12-27-2011 02:31 PM
RE: Need Rossi .90 small heads
I think you are going to find those heads hard to locate. A possible solution is to machine yours down, a lathe will probably make small ones out of large ones if you can find a way to mount them up.
Jim Oliver 12-27-2011 03:05 PM
I have looked at doing what you mentioned; also, on this particular engine, it appears that a std. Rossi .60/.65 head can be made to work by opening up the center hole several thousandths and also enlarging the counterbore that fits over, and secures, the head button. Not what I want to do, but sometimes you just gotta do what the job requires.......:eek:
Jim
Pylonracr 01-02-2012 02:42 PM
Jim;
I almost forgot. Look up the Engine Guy, Paul at Pauls Model Supply. [email protected] If anyone can get small cylinder heads for youhe can, he got some obscure Webra ducted fan engine parts for me for an engine that has been out of production for 15 Years.
Hope this helps
Good Luck
Scott
Jim Oliver 01-02-2012 05:44 PM
Scott,
Thanks, I'll give it a shot.
Jim
Jim Oliver 01-03-2012 08:28 AM
Paul responded quickly to my E mail, but didn't have anything that would help with my problem.
I may yet wind up trying to mod a current production head.
Jim
VampeD4 04-12-2013 12:23 PM
i may have what your looking for. email me for more info. [email protected]
http://www.ua-clan.com/rossi/HPIM0039.JPG
http://www.ua-clan.com/rossi/HPIM0040.JPG
http://www.ua-clan.com/rossi/HPIM0041.JPG
http://www.ua-clan.com/rossi/HPIM0043.JPG
Allen
SPEED JUNKIE 04-12-2013 03:34 PM
Are you talking about the head button or the cylinder head? I have a bunch of stock .90 Rossi parts new in the bag.
Jim Oliver 04-12-2013 04:31 PM
Hello SPEED JUNKIE,
Don't need the head button; the small cooling head (part with the fins) is what I'm looking for; two of my R90 DF engines have what I would describe as "large" heads, one engine has a "medium" size head. My older large case R90DF has the black colored cooling head, similiar in design to the pattern engines but larger.
Jim
SPEED JUNKIE 04-12-2013 05:03 PM
Let my crawl up into my parts bin in the attic and I will take a pic of what I have.
SPEED JUNKIE 04-15-2013 05:12 PM
Found one small Black Head in package and have two other Rossi's with Black heads.
Jim Oliver 04-15-2013 06:45 PM
Based on what I THINK I know, the later R90 DF engines might have had cooling heads very similiar to the .60-.65 engines, but with slightly different size relief cuts to fit the slightly larger .90 head buttons.
Any chance of pic and price?
Jim
SPEED JUNKIE 04-16-2013 08:26 AM
I have tried several times with no luck to upload pictures but it just won't work. 👎If you want it you can have it free of charge. I have plenty. I would rather see it being used then waste away. 👍 Just send me your address and I will send it out if u really want it.📍
Jim Oliver 04-16-2013 01:52 PM
PM sent.
Jim
