patriot wing ?
1 Attachment(s)
I'm wondering what you pat builders used to fill in these "holes"?
I've thought about some epoxy with balsa dust mixed in but I'm not sure. Any thoughts? |
RE: patriot wing ?
Hello Speedy, I used Hobbico Hobbilite balsa filler. Don't use epoxy because it will be a bear to sand!! You can use wood glue mixed with balsa dust also. Jim
RE: patriot wing ?
Hi, I use lightweight spackling, it sticks good, sands easy and its very light. You can get it at hardware stores, Walmart, Kmart, ect... comes in white only. Has NO structure value. If thats a XL what engine are you using and what size & brand fuel tank are you going to use? talk to me. thanks, RVBlack
RE: patriot wing ?
engine - ST90
tank - GP 12oz |
